However it is worse on some than others, for instance two identical A series engines but with different lengths of conrod, the engine with the longer conrods would see a lower vector force acting on the bore walls, therefore more power to the wheels
What you are seeing is the thrust of the piston on the power stroke, this is the early stages of "bedding in" or accelerated stages if it has been thrashed...... but either way this is where you will and are seeing the "initial wear" or bedding in of your engine.
the score marks, could be down to a bit of grit, did it have an air filter fitted at all times ?
it could be down to incorrectly fitted or damaged rings
Offset boring has been done on thousands of 1275 blocks it's 10 thousandths of 1 inch about 0.25mm its going to have so little difference to your thrust forces.
5.75/0.010 = 575:1 ........... oh and 0.010 is the tolerance for the bore on an A series engine, so you could find it is already offset bored before you even start......
