damn wrong section
Edited by danrock101, 26 April 2009 - 09:29 PM.
Posted 26 April 2009 - 08:58 PM
Posted 27 April 2009 - 09:41 AM
Posted 27 April 2009 - 10:05 AM
How about this for a laugh? www.comedy ebay manifold.com
Posted 27 April 2009 - 11:59 AM
nice one cheers, it looks cheaper than I thought thenAll the kits you can buy at the moment use the bini eaton M45 supercharger too.
You're looking at £100+ to get one on ebay.
You'll also need to get the manifolds custom made, unless you can find some on ebay which seem to pop up now and again. how about this for a laugh? www.comedy ebay manifold.com
then you need to sort out some kind of lower pulley capable of running a belt to drive the charger, a suitable length belt, and a method of tensioning it too.
With all that done, you'll need to make sure you're CR is low enough, which will either require a nasty decomp plate, or having your head chambers taken out to lower the CR.
Is the rest of your car up to it as well? taking a mini instantly up to 130bhp+ is a huge jump, and if you're still on standard brakes and suspension it'd be pretty foolish too I reckon.
Fast, cheap, reliable. You can only pick two.....
Posted 27 April 2009 - 12:35 PM
Posted 27 April 2009 - 12:53 PM
Edited by danrock101, 27 April 2009 - 12:54 PM.
Posted 27 April 2009 - 12:54 PM
I think you might want to reconsider your options then mate.....
Whilst a super charger gives you some low down boost, it's only proportional to the engine speed, so at low revs, there's very low boost.
The supercharger power delivery is more linear, and it keeps many of the n/a characteristics of the engine, as boost increases with engine speed, max power is made high up in the rev range.
Most typical turbo's don't have very high rev limits. The T3 spools up around 3k, and from what I've read, most people don't usually go much above 6k revs, as the speed is in riding the torque, so you don't need to use the revs so much....
Posted 27 April 2009 - 04:51 PM
Posted 27 April 2009 - 05:00 PM
What's the cheapest you can make a DIY supercharger kit for? I've seen Bini superchargers on ebay cheap, I was just wondering why the cheapest kit I can find is a well over £1000
damn wrong section
damn wrong section
Roofless - what happened to the brakes/Stefan
Posted 27 April 2009 - 05:01 PM
Posted 27 April 2009 - 05:02 PM
No phone to check, post pm instead, haven´t got hold of you in the right place, sorry for the hi-jack../Stefanwrong place - but check your phone messages.
Posted 27 April 2009 - 05:07 PM
I will let you off just this once >No phone to check, post pm instead, haven´t got hold of you in the right place, sorry for the hi-jack../Stefanwrong place - but check your phone messages.
