Rear Shock Absorber / Damper Removal Problems
Posted 23 April 2009 - 05:25 PM
Has anyone had the same issue before? If so how did you overcome it?
The car has standard shocks.
Posted 23 April 2009 - 06:07 PM
Edited by frankiebateman, 23 April 2009 - 06:07 PM.
Posted 23 April 2009 - 06:13 PM
Posted 23 April 2009 - 06:24 PM
Posted 23 April 2009 - 06:36 PM
Posted 23 April 2009 - 08:28 PM
Jas
Posted 23 April 2009 - 08:30 PM
Posted 24 April 2009 - 10:06 AM
Tried the grips and doing it while full weight on the wheels but no luck. Looks like it'll be jjojjas' trick
Dont use grinder..totally useless cause u'll have the same issue as u'll be fitting the new dumpers.
Bungles pointed you the correct way.
Posted 24 April 2009 - 11:46 AM
why bodge it when doing it the right way is easier
Posted 24 April 2009 - 01:16 PM
Watch out for the bottom bolt, when i took mine off the passenger side i had a 'mare getting the shocker to come off. Turned out i had pulled the shock and rubber bush off but the steel sleeve that slides over the bolt was seized on. Had to CAREFULLY grind through it without touching the bolt underneath to be able to prise it off
Another tip whilst im here, if your replacing the old trumpets with hi-lo's or similar then instead of farting about trying to get the old one out i angle ground halfway through the trumpet in the middle and then hammered a big chisel in the cut. Smashed it in half in one hit as it is a cast, and reasonably brittle, part. The old nylon bit of the knuckle joints is a pain to get out too
Hope this helps,
Matt.
Edited by Waffs1984, 24 April 2009 - 01:16 PM.
Posted 24 April 2009 - 05:41 PM
While I appreciate the help there's no need to be like that is there?i'm glad someone can see my post
Thanks for that Matt! I didn't realise the tiny bit above the nut was seperate to the nut, thought it was some fancy locking nut. Hense the reason I didn't really get Bungle's post and just assumed he was referring to a different type of shock absorber. I will be fitting Hi-Lo's to it so will use your method.Yep, mole grips or small (4-5mm spanner?) on the flat bit that protrudes out the top above the nut - this is what it is flat for! Warning - it will give you back ache if you have a standard boot in the way and your trying to lean over and use both hands!
Watch out for the bottom bolt, when i took mine off the passenger side i had a 'mare getting the shocker to come off. Turned out i had pulled the shock and rubber bush off but the steel sleeve that slides over the bolt was seized on. Had to CAREFULLY grind through it without touching the bolt underneath to be able to prise it off![]()
Another tip whilst im here, if your replacing the old trumpets with hi-lo's or similar then instead of farting about trying to get the old one out i angle ground halfway through the trumpet in the middle and then hammered a big chisel in the cut. Smashed it in half in one hit as it is a cast, and reasonably brittle, part. The old nylon bit of the knuckle joints is a pain to get out too![]()
Hope this helps,
Matt.
Thanks again.
