No turning back now !!!!
#676
Posted 25 July 2006 - 12:52 PM
#677
Posted 25 July 2006 - 01:21 PM
Fancy one on the R1 ?????
Lol I fancy Cameron Diaz aswell but that doesn't mean I'm gonna get her!!!
To be honest I'd love one but a touch expensive at the minute....
#678
Posted 26 July 2006 - 09:28 AM
#679
Posted 26 July 2006 - 10:05 AM
#680
Posted 04 September 2006 - 08:29 PM
Keep up the good work, and get it finished !
Dave
#681
Posted 22 October 2006 - 07:34 AM
I have a few comments and questions...
1. Acceleration - I think your going to have an awful lot of trouble accelerating as fast as you predict / hope, ie McLaren F1 rivalling. Generally a supercar has a very heavy midmounted engine, so that when it accelerates this large mass is forced over the rear wheels via g-force, so creating a huge grip on their massive rear tyres. In your case you don't have much mass at all - especially near the back, plus limited rear tyre contact area, so I think your really going to struggle. I know you have traction control but all that will do is reduce maximum output to compensate for the lack of available mechanical grip. What it won't do is transfer 100% of the available peak power, as most supercars would be able to do. Also the limited suspension travel must hamper outright grip. So your effectively only going to be able to use a smaller portion of the output power and theoretical bhp per ton.
2. Vmax - What do you calculate your top speed to be? Every bike engined car I've seen so far has a top end around most hot hatches, ie 150mph max. I presume this is because a tiny engine is used with a very narrow peaky power band, therefore naturally has low torque. This lack of torque can only be compensated for with low gearing; even more so as the engine is not pulling a light bike, but a car at four times the weight. Thus the low gearing will dramatically lower the top speed potential.
Also what is the cda? I know a guy with a 500bhp 911 turbo (like the ruf yellowbird) who has a theoretical vmax of 225mph due to the gearing. However in reality it will only reach 190 as the shape is not very slippery. I suspect the aerodynamics of a mini are akin to a brick so this must have a big impact on the theoretical vmax.
3. Handling - I have heard that most rear bike engined mini's handle very badly indeed, particuarly referring to the zcar conversions. I notice your using dedoin to hopefully improve on this, but I am still concerned for your handling. It seems to be in development as you are building, rather than being designed from the outset by a race engineer. Does your design include any way for someone to alter a lot of the settings to dial in different handling characteristics if required?
4. Evaluation - When the project is finished I would be interested to hear if it was sucessful by way of hearing your lap times on track. Do you have any particular track or times in mind as a target?
Thanks for all the info I await. I admire your dive in approach and it makes great reading
Paul
#682
Posted 22 October 2006 - 08:59 AM
2. Most bike engined cars wouldn't even get to 150mph, the top speed is more likely to be 120-130mph as they will be geared for maximum acceleration. Top speed has nothing to do with torque, it is only peak power that matters.
3. I don't know who told you that the bike engined minis handle 'very badly indeed'. My mini is at least 5 seconds a lap faster around castle combe than my lotus elise and that is with only 3/4 throttle and the back brakes locking up at anything like moderate braking into a bend. With full power and the other mods I have done since then, I estimate more likely 15-20secs a lap faster.
Edited by R1minimagic, 22 October 2006 - 09:06 AM.
#683
Posted 22 October 2006 - 09:19 AM
P.S my radio control car has about 1500bhp/ton, but it's not very fast vmax
3. Some people who've driven them
Edited by 4WD, 22 October 2006 - 09:21 AM.
#684
Posted 22 October 2006 - 09:23 AM
#685
Posted 22 October 2006 - 09:36 AM
BMW 320d, bhp 163, VMAX 140
BMW 535d, bhp 272, VMAX 155 (TORQUE 560!)
Audi S3, bhp 225, VMAX 155
P.S look at some stats:
http://www.bmw.co.uk...t-bmwuk,00.html
What is the torque of a holeshot 450bhp engine? What is the gearing? Therfore what is the theoretical vmax?
Edited by 4WD, 22 October 2006 - 09:43 AM.
#686
Posted 22 October 2006 - 09:50 AM
My argument was that if you take an 'identical' car with 'identical' gearing then the torque doesn't effect top speed it is only the power output. For example you could have an engine with 200bhp, 100lbft, 15000rpm and another engine 200bhp, 200lbft, 7500rpm, they will both have the same top speed. However, the way they get to that top speed will be different.
I think your argument is more along the lines of take the same engine, add more torque, you will get a higher top speed, which is also correct as long as it still has a similar max rpm!
Also, difficult to compare modern vehicles as they are usually limited top speed by the ecu.
I would imagine a busa turbo engine would have at least 200lbft of torque if it is going to make 450bhp, nit sure on the base case engine figures but guessing around 170bhp, 100lbft, 10000rpm??
#687
Posted 22 October 2006 - 10:04 AM
At the end of the day all I wanted to know was what lap times will a busa mini post up on well known tracks. Obviously it will be great on gokart sized tiny tracks, or 0-60 drag sprints, but what about the real world proper size tracks? I wonder what sort of time it would manage at the 'ring, with long straights and less than mirror perfect surfaces. This is why I asked about the torque, handling and cda. This way a design like this can be compared to different cars, like the evo, radical or even F1 if you really insist!
Real life laptimes are what I care about. Just a friendly enquiery
#688
Posted 22 October 2006 - 10:10 AM
I think a turbo busa mini will do well on the long straights (e.g. Snetterton, Castle Combe, Donnington, etc) as you have lots of torque, power, bhp/ton, and gears! But i am not sure how well it would do on the twisties as it might be off boost all the time!!
#689
Posted 22 October 2006 - 10:25 AM
Also notice how Ruf tuned porsches are faster than those with more power in the real world. Ruf have a huge amount of torque, spread nice and wide across the full power band where it counts.
P.S
Due to all of above I suspect an ultima will kick sand in the busa mini's face all day long.
#690
However, VW has just launched a golf with a supercharger and a turbocharger, the supercharger feeding into the turbo, could see a lot more of those in the future I think. Lots of power and torque from only a small engine, good on economy too.
