Salt Corrosion On Alloys
Posted 20 April 2009 - 03:50 PM
Posted 20 April 2009 - 04:01 PM
Nitormors does this well, but will take the paint off the inner rim too. Essentially your looking at refurbing the whole wheel.
You could try sanding it all off, but it will take you days! You'd then need to repolish the rim with fine wet&dry, wire wool and polish.
Posted 20 April 2009 - 04:04 PM
Thats moisture getting under the lacquer. Only fix is to strip the lacquer off.
is this a common thing to happen? so would you just send them back to superlite to be refurbed?
Posted 20 April 2009 - 04:15 PM
I bought a set of old superlights that were in a right mess:
So i just stripped the paint/lacquer off with nitromors:
Then polished up the lip with some 400 grit wet&dry. This was during:
Thats as far as i got before i just gave up and fitted them how they were. The idea was to keep polishing with 600, then 800 then 1200, following by wire wool and polish to give it a real good shine. But obviosley this would have taken forever.
I plan to get the rim polished up professionally, then respray the centres black.
Whatever you do, just don't lacquer the rim again, you'll only end up refurbing them again a few years down the line.
Posted 20 April 2009 - 04:17 PM
If you use good wheel sealent from when they are new they should never corrode, wish I knew this when I had mine .
Mine before (this was the best one):
After:
Paul.
Posted 20 April 2009 - 04:19 PM
Posted 20 April 2009 - 04:23 PM
Nice job there paul, thats what mine would have looked like but i just didn't have the patience!
Posted 20 April 2009 - 04:28 PM
I use 'poor boys wheel sealent' excellent stuff.
Paul.
Posted 20 April 2009 - 04:31 PM
Although the dish is about half the size i suppose...
Posted 20 April 2009 - 10:39 PM
If you (or anyone else even) would like any advice on any metal polishing or wheel refurbishment then just give me a shout as i used to do quite a bit as a hobby.
Have a go its surprising what you can achieve with a bit of effort.Plenty of patience needed for a really good finish though.
For example these used to be set of £70 wheels from the breakers yard.
Edited by rosco454, 20 April 2009 - 10:43 PM.
Posted 21 April 2009 - 12:08 AM
WHat technique did you use to polish those? I want to get my polished rims like a mirror!
Posted 21 April 2009 - 12:16 AM
Posted 21 April 2009 - 05:50 PM
so just to make sure im going to do this right-
1. get lacquer off - 600 wet and dry
2. quick going over with 1500 wet and dry
3. polish with ball on drill and metal polish
4. wax sealent to protect wheel
just one more question, if i do wax them, how do i clean them after? just like before with some alloy cleaner? and do i need to rewax them again when i have cleaned them!?
Posted 21 April 2009 - 06:05 PM
Just wash them with your normal car shampoo and top the wax up every few months.
I used 240 wet and dry to get the laquer off and rough sand the wheel, as you will be forever and will give it up with 600.
Use 600 then 1500 to smooth the scratches out.
Paul.
Edited by Pauly, 21 April 2009 - 06:05 PM.
