Auto Trans: Early Vs Late
#16
Posted 20 April 2009 - 08:30 AM
#17
Posted 20 April 2009 - 08:36 AM
#18
Posted 20 April 2009 - 08:57 AM
Torque convertors are about £236 plus VAT exchange
#19
Posted 20 April 2009 - 09:03 AM
#20
Posted 20 April 2009 - 09:25 AM
The pressure gauges are simple enough gauges probably available off the bay for a £5 plus an adapter.... ok if it only needs to work once or twice. People get all scared of the auto transmission and what they fear is that they often don't know enough about... so they sell you something they do know.......... which tends to be manual trans.
#21
Posted 20 April 2009 - 09:40 AM
Boris is an auto and unfortunately due to holding an Automatic Licence due to dissability i dont have a great deal of Choice
This is the Second Mini Automatic ive had and had no problems with the other one its mainly down to maintainance
If the car hasnt had regular Oil changes then it may of suffered simply because of that
I think the gearbox is vastly underated,Granted i wouldnt want to take an auto on a track day but for normal road use when all the internals are in good order and with regular Maintainance and Oil changes you shouldnt really have any problems
As far as Garages saying its not worth the bother it depends where you take it?
I took Boris to a local Ex Rover garage run by all the original Rover trained mechanics (most of them near retirement age) and they said Boris wasnt worth the bother
They based it in their mind that old minis are only worth scrap,needless to say i just left i wont recomend them to anybody with their atitude
However take it to an automatic gearbox specialists and im sure they see it in a very different light?
Cost?
Well looking around another fully rebuilt box can be yours for under £500 and depending on where you go labour £300-£500 so its Around £800-£1000 all in,Granted it your auto is a budget banger maybe its not worth it?
But if like boris its treasured £1000 then regular Oil changes and they are bulletproof its the previous owners that have caused the Slipping on Boris,s gears by not changing the oil Enough and Using the Wrong Oil too!!!!!
I know im going to be shot down here but never ever put anything in an automatic other than a good quality 20w50 mineral oil regardless to what the stupid handbook says!!!!
I seem to remember a post some time ago somebody said they switched from 10w40 to 20w50 and it made things worse,i really dont believe this was the fault of the Oil but that the transmission was soo Stuffed it was too late!
weve caught Boris in the Nick of time though we plan on a refurb exchange box anyway in the future as boris is for keeps
I too would like to see the rebuild piccys anybody got the guts to do it themselves is brave but id love to see somebody have a go
Parts for the gearboxes as others have said JPAT theres nothing they dont do and if there is they can probably machine/manufacture it for you from scratch
The only part ive found to be pretty much unobtainable is the Oil Pump though im sure somebody could refurb one?
Long Live the Auto if we keep converting them there will be non left
Autos are just as important a piece of Mini History that should be reserved!
Interestingly enough people moan about the price of an Autobox Refurb but ive seen manual units that cost anything from £800-£2000 and thats not fitted
Huggz
Jodie
#22
Posted 20 April 2009 - 09:47 AM
#23
Posted 20 April 2009 - 10:14 AM
I couldn't agree more. People always tell you to get rid of the auto box or that it's not worth fixing but that's usually because they are trying to sell you something they actually have or because they don't understand it. Or worst of all simply because they personally don't like automatic transmissions. It's actually a fairly simple device mechanically speaking and very robust as auto boxes go. As with all Mini transmissions its downfall is that it has to run on multigrade lubricant oil that is constantly being beaten up by an engine, with an added lack of maintenance usually thrown in for good measure. If fewer people were scared of fixing them the price of parts would come down. The Rover manual goes into very great detail about the auto and how to test it, strip it and repair it. If you go to an auto specialist rather than a Mini specialist most of the parts are available.
Well said Dan
I often drive my partner mad because i go into deep thought mode about redesigning things a bit
i keep thinking if there was a way to seal off the gearbox from the engine and have oil in the engine and automatic fluid in the gearbox things may run a bit smoother and last a bit longer
If only BL had Encouraged Sir Alex on his Gearless projects think how much better the Auto could be
I must admit we were thinking of doing a transplant for another manufacturers Engine/Box but the difference by just changing from 10w40 to 20w50
So we are going to stick with the tried and tested A series/AP II combo but get a refurbed box
Huggz
Jodie
#24
Posted 20 April 2009 - 10:17 AM
Too many garages advice is to change to manual as they simply don't know how to service, repair and or set the things up....
#25
Posted 20 April 2009 - 10:50 AM
#26
Posted 20 April 2009 - 11:09 AM
The price for the master kit includes all gaskets, seals, friction plates etc..... its still not a bad price, and don't forget that some of the manual bearings are no longer available either
#27
Posted 20 April 2009 - 11:17 AM
Bloody H*** the price of parts Dan ?, its cheaper for a full rebuild kit for an auto than it is for a Manual...... I am working on some upgrades that mean that more power can be put through the auto..... as Joloke08 has said some people have a real need for an auto, and some of those same people might like a bit more acceleration
Hmm i might need an auto but that doesnt mean i drive like a Granny
I like the sound of that,more power?
Ive gotten to tahat age where my insurance isnt excessive so can get away with mods without being hammered,i wonder just wonder if an autobox could cope with a supercharger?
Huggz
Jodie
#28
Posted 20 April 2009 - 04:08 PM
-I won't be rebuilding the tranny myself! I'm just trying to gather as much info as possible for the shop that does.
-I'm in the U.S. That's why I'm trying to help out whoever I take the beast to. There is a shop near me that deals with British cars which actually has reasonable rates (AMAZING!). They have some experience with mini's and the autobox, but they havn't overhauled one before. They do work on other auto trannys though, and have british contacts, so I'll probably go to them. MRA Minis, I'll be sure to give them your contact info.
-Dan, how can I get a hold of the Rover Manual you are talking about? I've been searching on the web for a while, but you can imagine that putting "rover, mini, manual, transmission, etc" into a search engine brings back a variety of sites, but none of them have the Rover service manual.
-MRA, I have 2 holes in the dipstick. I'm assuming one is for the lower level and one is for the upper. I usually check after the engine has set for a while after a run. I'm using 20W50.
-I won't swap for a manual trans. Minis aren't as common over here, so there aren't that many spares here. Plus, I want to keep the SPI, which limits my options even further. I think I'll be money ahead by just fixing the auto. I really don't mind the autobox anyway.
Thank again for all the help. I'll keep you informed.
-Brian
#29
Posted 20 April 2009 - 04:22 PM
Edited by Dan, 20 April 2009 - 04:26 PM.
#30
Posted 20 April 2009 - 06:48 PM
I would think one of the bigger US dealers like Mini Mania or 7 Enterprises (are these now the same company?) would carry the Rover manual. You can get it from Mini Spares over here. If not British Motor Heritage publish a disc with all the tachnical data from each era of production that you should be able to get hold of from one of the specialists. The data in the Rover manual is very much limited to a strip down and rebuild service and testing data for a general Rover mechanic to use. Anything that falls outside tollerance usually says something along the lines of 'return for an exchange unit' or simply replace the entire transmission rather than telling you any very specific machining dimensions for repairs. Also I'd guessed you were in the US and that parts may be harder to come by and more things would have to be re-conditioned by your mechanic. This is why I suggested JPAT might have more details but the manual will be quite handy as a general guide to tearing the box down. The latest copy I have is part number AKM6353 and as I said the specialists should have it. For the data discs you might find information at the BMH-Ltd website.
Mini Mainia and Seven Enterprises are seperate, and niether has the Rover Manual. I will try Mini Spares or BMH. I believe the shop knows about JPAT, but I'll suggest them as well as MRA Minis.
Thanks for the info!!!
-Brian
