A Panel Replacement
7 replies to this topic
#1 Cooper1997
Cooper1997
  • 67 posts
Posted 13 April 2009 - 07:38 PM
I am looking to restore the front end of my mini cooper in stages starting with new door skins and A panels. I am sourcing my own panels from Moss Europe using genuine parts. As far as the A panels are concerned are there any other panels required such as an inner panel or A post panel? Does it depend on their condition? Any help will be gratefully received.
#2 widerim_pickup
widerim_pickup
  • 661 posts
  • Local Club: nope
Posted 13 April 2009 - 07:57 PM
Yor'll probably find you need to replace the rear edge of the inner wing as well as this rusts from inside where the a panel is folded over. The only way to find out is to cut old a panel off, but have a look at the edge where it joins the floor pan this will give a good indcation. Also possibly might need to do the scuttle closer as well but you can inspect this with a torch when the car is on axle stands.
#3 jjojjas
jjojjas
  • 272 posts
Posted 13 April 2009 - 07:59 PM
Guessing by your username that your on about internally hinged doors.
The A panel just fits where you see it. Theres nothing behind it except the A post and inner wing / foot board referred to as the fitch panel often in minis. Here its removed (albeit very roughly...), as is the door...
there is a good "fitting your A panel thread in this section at the top of the page
Jas
#4 jjojjas
jjojjas
  • 272 posts
Posted 13 April 2009 - 08:00 PM
ps. if your restoring, why not change the whole front end in one shot. It will be cheaper in time and paint in the long run.
Jas
#5 Cooper1997
Cooper1997
  • 67 posts
Posted 13 April 2009 - 08:49 PM
Jas
Thanks for that.
I had thought of doing the whole front end but to be honest its not that bad at the front; just the usual bubbling at the seams. I thought I may just have them tidied up and respayed and then change the panels next year. It will cost more over time but the "hit" will be spread out. I have had the car from new and I have no plans to sell so there is no particular hurry and the doors and A's are in need of urgent replacement. I want to use gen parts as well which increases the cost.
Stephen
#6 Waffs1984
Waffs1984
  • 437 posts
Posted 13 April 2009 - 09:21 PM
Hi mate,
Here's some pics of the a-panel area and inner wing/flitch panel bit from last week when i was replacing my front end ready for a fibreglass front. Note the BIG hole in the panel where the old airvent was lol! Patched it all up now using the old wing for metal sheeting :(
Hope this helps! By the way the a-panels are dead easy to replace, just be careful when cutting them out! I spot welded the bottom to the door step (which was also replaced in my case) and then a small seam weld along the top of the new a-panel.
Cheers,
Matt.
#7 woody17
woody17
  • 432 posts
  • Local Club: three valleys mini club
Posted 13 April 2009 - 09:47 PM
which moss branch?
#8 Cooper1997
Cooper1997
  • 67 posts
Posted 14 April 2009 - 08:22 PM
which moss branch?
I am planning to use the Stockport branch.
