Starting A New Install!
90 replies to this topic
#31 Dom
Dom
    Moved Into The Mazda
  • 10,685 posts
Posted 16 April 2009 - 07:53 AM
Maybe you didn't have a big enough box for your sub to get the bass you wanted.
I sacraficed looks for my sub box and it enables my 10" pioneer to kick out plenty of bass.
#32 dannyg2325
dannyg2325
  • 434 posts
Posted 16 April 2009 - 05:58 PM
Yeah dom i kinda dont, not for the type r sub anyway, i was running the absolute min airspace, still preformed really really, but i just like ridiculous bass!! lol
#33 Mini Adam
Mini Adam
  • 682 posts
Posted 16 April 2009 - 06:11 PM
any more pictures?
#34 dannyg2325
dannyg2325
  • 434 posts
Posted 16 April 2009 - 06:24 PM
nothing yet adam, still putting the engine in at the mo!! lol
but want to get cracking ASAP!! so more pic coming soon!!
#35 joakwin
joakwin
  • 958 posts
Posted 16 April 2009 - 09:30 PM
ive done tons of installs useing type r subs, mainly the 12's
and those subs don't do well in a sealed box,
they come to life in a ported box around 2-2.25cu ft^3 ea sub after port and sub
i did a chevy s-10 ext cab truck with 2 type r 12's ported in a 4.5 cu ft^3 box after port and sub
with about 50-60 sq inch slot port
with 2000watts rms and the truck was doing 155db's on the audio control mic on the dash
in my mini im going with a tc sounds tc-9 15in sub custom built with 1500watts,
cutting a hole on the back wall behind the seat
and porting the box thur the back deck lid
sub forward, port up
no rear speakers and some door pods that i havn't started to build yet
my system will be done later this summer
#36 dannyg2325
dannyg2325
  • 434 posts
Posted 16 April 2009 - 10:33 PM
make sure u start a theard on it!! would be good to see!
and yes totally agree about the R's. i do alot of custom install work myself being an authruised alpine dealer, but i just dont the ported or vented sound, too loose for my ears!! lol
#37 joakwin
joakwin
  • 958 posts
Posted 17 April 2009 - 09:57 PM
how a box sounds has to do with the port area
but a good rule of thumb is 10sq of port per every 1cube of air space for SQ
and 15sq of port per every cube for spl
i like to keep my boxes i build about 12-13 range
and tune pretty low, around 33-35hz
Edited by joakwin, 17 April 2009 - 09:58 PM.
#38 Mini Adam
Mini Adam
  • 682 posts
Posted 22 April 2009 - 07:34 AM
Done any more to it?
#39 dangregory007
dangregory007
  • 64 posts
Posted 23 April 2009 - 05:31 AM
Looking forward to seeing the install, if its as good as the kit going in it should be top notch!I'm planning a full Alpine install myself at the mo, but all Type R stuff.
What kinda alternator are you using? I'll be running about 1300WRMS between my 2 amps, and the biggest alternator I've seen specifically for minis is 70amps, so probably need about twice that...
#40 dannyg2325
dannyg2325
  • 434 posts
Posted 23 April 2009 - 08:53 PM
i was gonna say if you want a qoute for the alpine type r stuff to give me a shout and i will see what i can do. but i just noyiced ur in new zealand, so i dont no how the shipping would work out. but i suppose its worth a try. send me a pm with all the stuff you need and i will get u a price sure!
yeah biggest ive seen is a 70 also, so not sure what way this leaves me. just thinking dual battery in the mean time!
dan
#41 dangregory007
dangregory007
  • 64 posts
Posted 23 April 2009 - 11:29 PM
dan
Haha yeah shipping is a killer, I have to pretty much double the price of anything I get from Minisport by the time I've included shipping >_< . Thanks for the offer anyway, would definitely give you a shout if I was over there! I've got it all sorted though, should be picking it up next week.
Actually being an Alpine supplier, maybe you can advise me on a problem I've been tossing up for a while. I've got an MRD-M605 at the mo (660WRMS from the test card), and was really in 2 minds wether to get Type R or Type S subs (2x10" wired to give 2ohm). 660W is kinda at the limit for 2 Type S ones, but sorta mid-low range power for the Type R (which I believe are designed for 200-500W each). I've pretty much decided that Type R would be sweet and leave room to upgrade my amp if I ever want to, and the recommended sealed enclosure size is smaller too,which is always a good thing in a mini! What are your thoughts?
As for the alternator dilemma, I don't think 2 batteries are going to solve the problem? I know there are companies that make massive output alternators, just haven't seen one for a mini yet, but I spose they're all the same, just need a bracket and electrical plug modification...
#42 dannyg2325
dannyg2325
  • 434 posts
Posted 23 April 2009 - 11:49 PM
actually funny u mention that, i done an install last week using a 605 and 2 type r's. on a 2ohm load it actually performed really well. ideally for the type r as mentioned earlier, a ported or slot vented box is the better option. but we all know what space is like in a mini. however i found with plenty of wadding in a sealed box u can get very good results! its down to the setting up as well, if it properly tuned the 605 is more than capable. then consider a 2nd 605 as an upgrade. you shud be able to pick 1 up cheap now.!
as for shipping, i got a qoute for shipping to norway and it was only £50 GBP an that was 25kg worth of alpine!
#43 norwegianminiman
norwegianminiman
  • 323 posts
  • Local Club: norwegian mini cooper club
Posted 24 April 2009 - 07:18 AM
thats to me^^
any idea how I work out how much power I will need to get out of battery/alternator?
Edited by norwegianminiman, 24 April 2009 - 07:18 AM.
#44 mighty mini jack
mighty mini jack
    Mighty Before a Pint
  • 5,095 posts
Posted 09 May 2009 - 06:37 PM
Any progress on your build mate?
#45 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,722 posts
  • Name: Chris
  • Local Club: None
Posted 09 May 2009 - 11:05 PM
pics!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
