That's interesting but I must be missing something - surely it turns the cam in the wrong direction?
LOL If there wasn't the idle gear in between the other two it would go the wrong way
Edited by Nightrain, 10 April 2009 - 12:08 AM.
Posted 10 April 2009 - 12:07 AM
Posted 10 April 2009 - 07:32 AM
The oil drain down from the tappets goes through the timing chain cover to lube the chain, so even with a belt you still need the oil passage behind it. I don't think there's any reason a breather is needed there, it was just a convenient place to put it when they designed out the tappet chest covers. It doesn't require any alteration of the engine casting and, as it's not in the main crankcase, there's likely to be a bit less oil flying round in the air to get sucked up. You might be able to modify a later belt kit if you really felt a need for a breather, the Minspares kit fits the usual 1/2" hose but the actual vent is tiny, I actually drilled mine out to 1/4" from something even smaller.
Posted 10 April 2009 - 07:38 AM
Posted 10 April 2009 - 09:23 AM
the gear kit that was mention was done by Sir J Stewart back in the 60ies if I remember correctly, its great for a while and then it wears out and fast,
You can not have enough breathers on the engine and if you are running High Compression and running to 8,5K the more so
Posted 10 April 2009 - 10:11 AM
Posted 10 April 2009 - 10:24 AM
Posted 10 April 2009 - 10:36 AM
Posted 10 April 2009 - 10:40 AM
Posted 10 April 2009 - 12:58 PM
Posted 10 April 2009 - 02:32 PM
Posted 10 April 2009 - 03:00 PM
Slark supply MED, with the gear driven set.
Edited by mini7boy, 09 May 2009 - 02:05 PM.
Posted 11 April 2009 - 06:57 PM
Posted 09 May 2009 - 02:08 PM
