did alittle more work/welding on the valance project
its slowly coming along, lots of more work to go
really like the look of the front valance! makes a change
Posted 07 October 2010 - 04:32 PM
Posted 11 October 2010 - 06:59 AM
Posted 15 October 2010 - 12:10 PM
Posted 15 October 2010 - 12:13 PM
Posted 15 October 2010 - 01:25 PM
Posted 15 October 2010 - 02:12 PM
Posted 15 October 2010 - 02:14 PM
Posted 15 October 2010 - 03:37 PM
Posted 15 October 2010 - 05:10 PM
i think im gonna fill the exhaust recess hole, and if i don't like the way it looks,Are you going to fill in the exhaust recess on that front valance? Looks a bit wierd with it there!
Posted 18 October 2010 - 09:14 AM
Posted 18 October 2010 - 09:36 AM
Posted 19 October 2010 - 06:36 AM
a few small parts i had to use a hammer and dully on, but about 90-95% i didn't have toany updates mate??.... when you deseamed the roof gutter did you have to hammer the panels to match up together??
Posted 19 October 2010 - 06:55 AM
Posted 19 October 2010 - 04:29 PM
Edited by joakwin, 19 October 2010 - 04:34 PM.
Posted 22 October 2010 - 05:05 PM
the biggest problem is the water channel, theirs like a little "C" looking shape right before the seam
i spot welded the seam, and then i went back and filled the "C" channel with weld until it was above where i needed it to be
and then grind it back down to it was flush with the body shape,
i didn't want to just fill it with body filler,
i did about 2 weld lines just for the seam area, one on the seam and one below the seam,
and then about 6-8 weld lines(spot beads) for the "C" channel area
grind it down, and then spot weld the areas that looked like it needed alittle more filling
and grind somemore and do that over until it looked like it was good
my goal is to try and use as little body filler (bondo) to make the lines flow right
the "C" channel areas around the front and back windows where alot bigger then the channel area on the side of the vehicle's rain gutter
the side area didn't seem to need as much weld filling for that "C" channel,
if u look very close, you'll see the channel im going on about, i don't know what else to call it, so im calling it that,
its right where the base of the roof connectors to the rain gutters
since i used to work as a full time welder at the vehicle maints shop i work at, i love welding and metal work,
it wasn't to bad of a job for me to pull it off, alot of grinding wheels and cut off wheels to de-seam the car
but ive done everybit of metal fab rebuilding this car myself
