84 Mayfair Project
255 replies to this topic
#16 joakwin
joakwin
  • 958 posts
Posted 08 May 2009 - 01:15 PM
my adjustable suspension parts
just need to order new control arm bushings
and coil conversion kit and my front suspension will be 100% rebuilt
peace
#17 joakwin
joakwin
  • 958 posts
Posted 08 May 2009 - 01:20 PM
wipac halogen light kit
im gonna wire it up with relays, so i still need to get relays before i can install them
#18 miniallsort
miniallsort
  • 4,723 posts
Posted 08 May 2009 - 09:21 PM
looks great
#19 joakwin
joakwin
  • 958 posts
Posted 09 May 2009 - 01:32 PM
im thinking two spot lights right in the center of this thing
im gonna try and see if i can find some halogen spot lights
#20 joakwin
joakwin
  • 958 posts
Posted 14 May 2009 - 09:41 PM
got some new toys in the post
front and rear Gaz adjustable shocks
#21 joakwin
joakwin
  • 958 posts
Posted 14 May 2009 - 09:50 PM
this is what the shocks look like, drop shocks, they look nice, i can't wait to see how they will ride
#22 joakwin
joakwin
  • 958 posts
Posted 14 May 2009 - 09:53 PM
hd tie rods from mini spares
not pictured, a set of poly and rubber bushings
im not sure yet but im thinking about paint the tie rods a gloss black
#23 joakwin
joakwin
  • 958 posts
Posted 14 May 2009 - 09:57 PM
my stock lca and brake shield cleaned up and painted gloss black
i just ordered poly lca bushings
after that all i will need for my front suspension is new cones and it will be done,
one step at a time
#24 joakwin
joakwin
  • 958 posts
Posted 14 May 2009 - 09:59 PM
new inner cv joint boots
and the other day i built the front end ball joints
#25 joakwin
joakwin
  • 958 posts
Posted 14 May 2009 - 10:02 PM
the cowl hood is almost done with all the welding work
i have one side of the hood fully welded up
and the other side needs about 5inches to be welded still
ones i get the welding done, then im gonna grind it down and do
the body work and paint myself
but the grinding will take me a few weeks to get done because
im doing other stuff to the car as well
#26 joakwin
joakwin
  • 958 posts
Posted 14 May 2009 - 10:13 PM
and the last picture for the night
the start of the system for my mini
tc sounds tc-9 magnet
and tc sounds oem audiomobile mass 2012 basket
i now have a pair of baskets and matching magnets
so now i need to save up for my recone kit and the subs will
be like brand new again
its gonna cost me about 180pounds to get the recone kits(pair of 12's)
with shipping to out here in the uk from the states
custom built to whatever spiders i want, whatever ohms of the coils,
whatever wire i want the coils built out of
to handle whatever rms power i want them to
oh yeah, 3inch coil and the magnet weighs 25pounds, about 11.33kg's
#27 joakwin
joakwin
  • 958 posts
Posted 15 May 2009 - 09:34 PM
today i rebuilt my drivers side cv shaft
i took the bearings out of the joints and cleaned them
and then i re-did the grease in them and put it all back together
i had to put new inner cv boots, so i said screw it and went all out on it
so next week sometime im gonna do the samething to the passager side
my poly lca bushings were ordered today
along with my rear roll pan
#28 joakwin
joakwin
  • 958 posts
Posted 29 May 2009 - 08:29 PM
today in the post i got
new track rod ends,
ball joints( i needed new boots so i had to order the kits),
rear roll pan,
diff axle seals,
lca poly bushings,
exhaust hanger mounts,
oil filter,
steering arm lock washers,
knuckle joints
fan belt
and im still waiting on the steering rack boots to come in, probably be in monday
and this weekend im picking up my fiberglass dash
i still need to paint one steering arm and my uca
so my next thing to order is gonna be
a full dynamat extreme sound mat kit or the fiberglass door cards
im thinking im gonna do the mat 1st so i can install it this summer while we have some good weather outside
and the door cards next pay period
Edited by joakwin, 29 May 2009 - 09:25 PM.
#29 joakwin
joakwin
  • 958 posts
Posted 29 May 2009 - 09:32 PM
here's a mock up picture
new knuckle joints, hi-lo's
and re-done upper control arm
and my old rubber cones cleaned up a bit
still not sure if im gonna get new rubber cones or not
Edited by joakwin, 29 May 2009 - 09:32 PM.
#30 joakwin
joakwin
  • 958 posts
Posted 01 June 2009 - 04:05 PM
here is my last upper control arm ready for paint
and the 1st of the rear trailing arms ready for paint
i sanded them down with a wire bush and then sanded them by hand
to get as much rust off as i could
and then some rust protection paint, gloss black
and its good to go ones the paint drys all the way
