84 Mayfair Project
255 replies to this topic
#226 joakwin
joakwin
  • 958 posts
Posted 05 June 2014 - 09:15 PM
I mounted the front clubby clip back on last night and today i did some cutting on the wheel openings
i want to re-paint the bumper, i did it a long time ago and its kind of dusty now and the black faded a small amount
i mounted the arches alittle high on the clip, but theirs a plan for that.....
Edited by joakwin, 05 June 2014 - 09:16 PM.
#227 joakwin
joakwin
  • 958 posts
Posted 19 July 2014 - 08:33 AM
painted the valve cover, and while I had the cover off, I checked the valves, I pulled half of the Honda harness from the car,
I have a rywire D series harness and chassis adapter harness in the mail right now
http://www.rywire.co...t-p/b1-base.htm
http://www.rywire.co.../b-sub-race.htm
$693USD shipped
the harness has made its way from California and just left Chicago last night at 10:40pm
i'll probably have it by Tuesday/Wednesday
so that gives me a few days to install it and im going to try and get it on the dyno at http://www.tdi-plc.com/ on Saturday the 26th
and MOT the 2nd
so I can try and make it to IMM with the car
if I cant do it, then I want to bring it to mitp
#228 joakwin
joakwin
  • 958 posts
Posted 23 July 2014 - 03:40 PM
rywireenginechassisharness_zpsad5e1a60.j
rywire harness with chassis harness, the alt wiring was ext 24inches
Edited by joakwin, 23 July 2014 - 03:40 PM.
#229 joakwin
joakwin
  • 958 posts
Posted 31 July 2014 - 11:05 AM
used dizzy from the junkyard cleaned up  and swapped
Edited by joakwin, 31 July 2014 - 11:06 AM.
#230 joakwin
joakwin
  • 958 posts
Posted 31 July 2014 - 11:07 AM
making a exhaust tip for my new set up, 2.5in pipe
#231 joakwin
joakwin
  • 958 posts
test fit new exhaust tip before welding in
#232 joakwin
joakwin
  • 958 posts
Posted 31 July 2014 - 11:08 AM
new battery set up
#233 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 01 August 2014 - 11:43 AM
I get really excited when i see pictures of the front end of this car all assembled.
Nice Job
#234 joakwin
joakwin
  • 958 posts
Posted 10 August 2014 - 05:42 PM
ive been working on the tune on the car,
been driving it on the road and datalog it and then make changing in the tune
its almost ready for mot for real this time
thanks, everytime I walk into the mini shop, I see this car, I just cant wait to get behind the wheel and drive
Edited by joakwin, 10 August 2014 - 05:43 PM.
#235 joakwin
joakwin
  • 958 posts
Posted 14 August 2014 - 09:12 PM
http://www.ebay.co.u...r-/171396563949
i'll be mounting this in my car in a few days
#236 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 August 2014 - 05:23 PM
That is really quite smart!
Must remember to have one in mine
#237 joakwin
joakwin
  • 958 posts
Posted 24 August 2014 - 02:27 PM
Been battling a brake fluid leak at the front left caliper, it's so small of a leak, but if I run my hand on the fitting, i can feel alittle bit of brake fluid, so I replaced the fitting and made the leak like ten times worst, so I'm changing the fitting again and this time I think I should be good
Picked up a few bottles of brake fluid, so I will bleed this thing out in the front again, it's a pain in the rear but I want it 100% right before I take the car for mot
But the nice thing about it is my master cylinders use two for the brakes
Edited by joakwin, 24 August 2014 - 02:28 PM.
#238 joakwin
joakwin
  • 958 posts
Posted 07 September 2014 - 07:27 PM
im rebuilding the exhaust again for the like3rd or 4th time now, I forget
but I don't care if it takes me 10 times, if im not happy with it, I will re-do it until I am happy
I made the y-pipe tuck closer to the oil pan, and then the connector pipe of the y tuck even closer
so since I did that, I have to re-do the rest of the exhaust because it now hits the shifter rods
one thing effects the other
the outlet out of the y-pipe is 2.5inches
Edited by joakwin, 07 September 2014 - 07:28 PM.
#239 joakwin
joakwin
  • 958 posts
Posted 28 May 2015 - 03:46 AM
wow, so much has gone on since I last posted anything
the car was shipped out of the UK in Dec 2014
the car was taking apart and a rolling shell was shipped from Southampton to Port Hueneme, California
and then it was towed to San Diego California, and then towed to Yuma AZ
and then towed to Tucson AZ
the night it left on the tow truck to the Southampton
#240 joakwin
joakwin
  • 958 posts
Posted 28 May 2015 - 03:48 AM
the lhd mini with my brothers gasser 55 chey, 427bbc with 550hp
