84 Mayfair Project
255 replies to this topic
#181 joakwin
joakwin
  • 958 posts
Posted 25 February 2012 - 10:31 PM
Mock up of the clubby abs motorsports grp front clip Posted Image
#182 joakwin
joakwin
  • 958 posts
Posted 25 February 2012 - 10:32 PM
#183 joakwin
joakwin
  • 958 posts
Posted 25 February 2012 - 10:34 PM
Carbon fiber boot floor from absmotorsports
#184 joakwin
joakwin
  • 958 posts
Posted 25 February 2012 - 10:38 PM
Cut the boot floor out, getting ready to put the CF in
I sanded down the metal to bare metal on the underside and primed it and covered it in bed liner
#185 joakwin
joakwin
  • 958 posts
Posted 25 February 2012 - 10:43 PM
Sanded the subframe panel down to bare metal and painted it and bed lined it also
So far I got the rear beam mounted up to the shell but I still need to cut the boot floor to fit the opening and
I'm waiting for my tube bender to come from the states
The tube bender im getting comes with one die to bend with, Im getting the 1.5 or 38mm die because that's the size of the CDs my
Cage is made out of
#186 joakwin
joakwin
  • 958 posts
Posted 25 February 2012 - 10:47 PM
I picked up the pair of seats with mini subframes used for 60gbp, gonna stick them in my
Daily driver Nissan micra hatch, lol and I stuck my mb quart 1500.1 sub amp with the tc sound 10inch sub into
The micra also
#187 joakwin
joakwin
  • 958 posts
Posted 25 February 2012 - 10:52 PM
Here I was doing the wiring, I used a wiring harness from speedway motors from the states, the harness is for a
Hot rod and I made it work for the mini chassis/engine
#188 joakwin
joakwin
  • 958 posts
Posted 25 February 2012 - 10:57 PM
The harness was fun,
A hot rod harness with mini switches/controls and mk1 metro clocks
Everything has been solder and heat tube covered
Moved the switches to the right side of the steering wheel
#189 joakwin
joakwin
  • 958 posts
Posted 10 March 2012 - 01:21 PM
#190 joakwin
joakwin
  • 958 posts
Posted 11 March 2012 - 09:52 AM
#191 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 14 March 2012 - 08:21 PM
NICE !!
#192 joakwin
joakwin
  • 958 posts
Posted 20 March 2012 - 12:04 PM
i didn't like the look of the little bit of blue you could see, so i took it apart and cleaned the lube out and painted the blue billet black
and then waited a day for the paint to dry all the way
and put it all back together
seems like so much work to just put hubs on a axle
#193 joakwin
joakwin
  • 958 posts
Posted 20 March 2012 - 12:06 PM
started to mount the coilovers, not 100% sure yet if they are gonna stay chrome
trying to get a feel for it right now, and sleep on it for a week or two
Edited by joakwin, 20 March 2012 - 12:07 PM.
#194 joakwin
joakwin
  • 958 posts
Posted 06 April 2012 - 03:18 PM
a new toy came in the post the other morning
my 1st bend with it
38mm cds tube
the rear section im adding on to my rear roll cage,
still need to bend up the cross bar and weld the saddles onto the other side's rear section tube
should have this rear section done in a few days
#195 joakwin
joakwin
  • 958 posts
Posted 10 April 2012 - 09:12 PM
just got done with the rear section of the cage building
the legs go all the way down to the upper coil over mounts
