84 Mayfair Project
255 replies to this topic
#166 joakwin
joakwin
  • 958 posts
Posted 20 April 2011 - 06:20 PM
somemore pics of the sub box, got a ton of sanding to do on it but i can't wait to hear it
gonna wait to install the top panel to after i got the sub hole out
#167 joakwin
joakwin
  • 958 posts
Posted 04 May 2011 - 06:06 PM
i started to sound mat the car,
i ordered 36sq feet of dynamat to start out with
20sq feet went to the roof and 16sq feet went to the back seat area
i need to order more matt, because i still need to cover the rest of the side panels, area under back window, floors, firewall, doors
gonna use alot more sound mat on this project, should make the car not sound so much like a tin can
#168 joakwin
joakwin
  • 958 posts
Posted 20 May 2011 - 09:13 AM
got most of the bed liner put down on the floor of the shell, will help with the leaking of water into the car,
i got a small leak on the right side right now but i don't have my door check seals installed, so im pretty sure thats where the water is leaking into the car from
i got some new ones but i can't remember where i put them at, so im probably gonna have to go buy somemore, lol
they are only a few quid so not a big deal
i ordered heavy set of grp doors from the arc, i can't wait to see them
i want to weigh a steel door vs the grp door
i want to get some dsn classic hinges for them and the lexan windows
anyways, ive been working on my interior a bit, i need to make or order a wiring harness for the car before she can run
so im working on the interior till i get around to the harness
#169 joakwin
joakwin
  • 958 posts
Posted 20 May 2011 - 09:15 AM
im not 100% sure if i want to go with those seat belt harnesses right now, so i havn't welded in a harness bar to the roll cage,
im just trying to get a feel for them, if not then i can always pull them out and put reg seat belts in
#170 joakwin
joakwin
  • 958 posts
Posted 26 May 2011 - 12:42 PM
#171 joakwin
joakwin
  • 958 posts
Posted 26 May 2011 - 01:10 PM
grp heavy street doors from arc angels
#172 joakwin
joakwin
  • 958 posts
Posted 13 November 2011 - 03:47 PM
test fitting the doors
and got the hinges mounted to the doors now
#173 joakwin
joakwin
  • 958 posts
Posted 13 November 2011 - 03:48 PM
Posted ImagePosted Image
#174 joakwin
joakwin
  • 958 posts
Posted 13 November 2011 - 03:49 PM
and started to install the new wiring harness
#175 joakwin
joakwin
  • 958 posts
#176 joakwin
joakwin
  • 958 posts
Posted 15 November 2011 - 11:57 PM
mini sport inner door handles
#177 joakwin
joakwin
  • 958 posts
Posted 22 November 2011 - 01:22 PM
sc stainless header
im gonna be the 1st one to fit one of there lcb to an auto engine
sexy header for sure
#178 joakwin
joakwin
  • 958 posts
Posted 25 February 2012 - 09:25 PM
Wow, I havnt update this thread in a long time
The wiring for car is done, I got a grp clubby clip from abs motorsports and a carbon fiber boot floor,
And I got a rear beam from min tec with some qa1 coil overs
And blue billet hubs from http://www.specialis...mponents.co.uk/
And a single skin boot lid from arc angels
And a grp rear valance
And I'm about to order a mandrel tube bender, I'm gonna add on to my roll cage
Gonna make a bar to go from the b palier down the c palier and connect to the top of the rear shock towers
And make a bar to connect the two sides at the top of the c palier and then another bar inside of the boot close
To the shock tower, witch the shock towers will be the top mounts for the coil overs
#179 joakwin
joakwin
  • 958 posts
Posted 25 February 2012 - 10:27 PM
Posted Image. Rear qa1 coilovers
#180 joakwin
joakwin
  • 958 posts
Posted 25 February 2012 - 10:29 PM
Mini tec rear beam suspension
