Thanks guys, it's good to have some encouragement =) Need some advice too, I've been using about 100 grit sandpaper to get the shape right, but trying to smooth it with 240 it just clogs up the paper straight away. Read about stopper but there isn't any in halfrauds, so the idea of mixing resin with filler to get a smooth mix is in my mind, will that mean less sanding? =)
Thanks sweetser
Rosco, valance was £30 I believe, it was however a little short so I've been trying to fill it out to follow the panels above. It's a bit more work than a genuine panel probably if you want it perfect.
Cookie, I'm planning to use the normal hinges at the moment, I fibreglassed over them but I'll drill them out from behind =) I don't like the numberplate light on the boot though and there's a nasty dent in the skin, so might get a smooth fibreglass skin at some point, but I'll probably still keep the hinges.
Thanks mozzo, I'll try find your thread, if I dont, link me!
Cheers again for the interest and any advice on the filling welcome.
Edited by daveeeeee, 01 June 2009 - 09:23 PM.
