Hi Mark. Airbox looks the danglies. Are you planning any dyno time to remap the ecu to suit? It's not the same obviously, but the R1 is very sensitive to airbox/exhaust mods.
Will have a power commander fitted soon and setup in time for a rolling road shoot out at minisport which is organised by M******ITY in April.
As for tonights progress, i have set up all the suspension on the car now using tracking gauges, castor/camber gauges and the turntables.
It was a time consuming job but well worth it to know it is all spot on so far but a road test tomorrow may settle things a little so it may need a tweak again?
Heres this evenings going's on.........
Here is the castor and camber gauges being used.
After a lot of adjusting and setting of the front suspension i got everything to stay at the settings i wanted as when you adjust the castor it moves the camber & tracking slightly a which also needs to be reset before a measurement is made.
Anyway it was friday night and a day off tomorrow so the bench began to get a little crowded!!
I only have the rear tracking/camber to adjust in the morning as it is set parallel for now but it doesent take long to adjust but set the gauges up tonight ready
Just a wash and polish left to do then playtime sunday!!!!
