Well i was away again at the weekend so no progress again but i have spent every evening on it till midnight al this week sorting the wiring loom out.
Once again as i have never owned a mini before i have discovered that the quality of the switches and fusebox is not really very good and may cause problems for the future.
So I have decided to construct my own loom from scratch using only the original steering column switches and hazard switch, Everything else is new.
The underbonnet wiring loom is finished except for putting the plugs on the headlamp connections and connecting the indicators which have been supplied by Colin @ Northwest minis
I hope to be able to fit the front end next week so it will really start to look like a mini but i found it easier to do all the under bonnet work without the fron end on.
Wiper motor and washer bottle now fitted finally.
Also managed to hide the wiring loom and run the cable through the bulkhead
This is what im doing now, it looks a long way of yet but a few more nights should have it all done.
I have mounted the relays and fusebox under the passenger side of the dash so it will be easy to get to.
I havnt fitted all the relays yet as the flasher units are to be plugged in there aswell.
Here is the dashboard under construction, i still need to finish off the holes to get the rough edges smoothed off then remove the switches etc to cover it ready for refitting.
I have also been speakin to a few people about mounting the oil pressure gauge take offpipe into the engine block as the standard hayabusa oil pressure switch is underneath the engine and most people just fit a T-peice and replace the switch and fit the pip to the gauge but these have been known to crack and leak so i didnt want torun the risk so the other way is to have a fitting with an adapter into the side of the engine where suzuki have fitted a blanking plug in the main oil gallery. I then plumb it up to the gauge in Goodridge brake line pipe which is more than adequate for the job.
I will probably update a bit more next week now as im away at the weekend again now.
