HAYABUSA POWERED COOPER R.W.D.
#166
Posted 19 November 2005 - 06:22 PM
It is also touching the ridge inside where the rooflinghing sits on both sides which hindered the fitting of the kit a little. but a little dressing of this area when i remove the frame will sort this. The main rollcage hoop must be too tall by a 1/4" as it is just fouling and has marked the powder coating a little but it wont be seen when the windows are fitted.
Mark :wales:
#167
I see what you mean about the rear wheels, they look quite far forward already.
#168
Posted 19 November 2005 - 06:31 PM
I have had to raise the spring seats up 10mm to provid clearance on the inner arches for now.
Providing the wheel alignment doesnt need too much adjustment i may be able to wing the trailing arms back about 1/4" to even the gap up a little but with the way the suspension moves in arc as it raises it moves the wheel back in the arch anyway.
Mark :wales:
Posted 19 November 2005 - 10:52 PM
Steady on Dale, there no need for that, although I have spent a lot of time on it.I think R1mini will be the last, he's a right slacker!!!
:fear: :fear:
It doesn't look much, I shall take some piccies and start my own thread soon
R1mini
#170
Posted 19 November 2005 - 11:24 PM
Mark :wales:
Posted 20 November 2005 - 01:26 PM
Ive got a few bits to chase up on the braking department bias pedalbox or master cylinder?
Mark :wales:
#172
Posted 20 November 2005 - 01:37 PM
Do you know if you can reduce it that much on the bias bar??
I think i will remove the servo and fit a normal master cylinder (yellow band disc brake type, i think they are the same internal bore??) and then get a bias valve fitted to reduce the pressure going to the back. The brakes feel ridiculously over servo'd at the moment. However, i need to drive the car with the servo disconnected and see what i think.
#173
Posted 20 November 2005 - 01:50 PM
5/8" for the front and at least a 3/4" for the rear possibly 7/8".
I just cant get over the price for a standard mastercylinder then you still need a bias valve for the rear line aswell so your over £200 for that lot. Kad pedalbox £160 plus £25 a cylinder so it works outt he same really and the kad is probably a better set up and less to go wrong with valves etc
Are you on a servo???
#174
Posted 20 November 2005 - 02:07 PM
#175
Posted 20 November 2005 - 02:13 PM
They will sell them at KAD but i can get them a lot cheaper from Demon Tweeks.I should have a couple of those master cylinders lying around somewhere, so i will use those to start with. Also, losing the servo will knock some more weight off and give a lot more space under the bonnet. The KAD setup does look very nice though!! Do they sell the different size master cylinders at KAD?
Im still waiting on a phone call for this little beauty (Genuine Group A Rover mini pedalbox)
Plus he also has a full group A front brake setup aswell
Mark :wales:
Posted 20 November 2005 - 02:17 PM
Where are these from??
#177
Posted 20 November 2005 - 02:27 PM
They are no longer available as they only built 2 Group a coopers and 1 was sold and 1 was broken up. I have got hold of him through the rallying as he is now preparing Mitsubishi evo's but has a few mini bits left over. The front brakes and calipers are seperate discs and alloy bells so i dont know if they will fit under 13"'s
If i get the pedal box im sure i can copy it anyway as i doesnt look a lot too it?
Cheers Mark :wales:
#178
Posted 20 November 2005 - 02:30 PM
#179
Posted 20 November 2005 - 02:41 PM
Mark :wales:
Posted 20 November 2005 - 02:46 PM
