HAYABUSA POWERED COOPER R.W.D.
565 replies to this topic
#136 Dick Dastardly
Dick Dastardly
  • 261 posts
Posted 16 November 2005 - 03:30 PM
Mark, the tacho is incorporated in the Veypor unit (I've got the standard Veypor car kit- not the VR2 model), and I'm running seperate guages for fuel level, water temp, and (eventually) oil pressure.
D.D.
#137 Dick Dastardly
Dick Dastardly
  • 261 posts
Posted 16 November 2005 - 03:32 PM
Oh yes, the price. I can't remeber how much it was now, but I remeber it being cheaper than the RRP mentioned on the website as it was one of the last of an old model or something along those lines. Sorry, not much help really....
D.D.
#138 markrally
markrally
    Z Cars
  • 1,378 posts
  • Local Club: Miniaddicts.co.uk
Posted 16 November 2005 - 03:39 PM
I had opted for the stack as it does everything, revs, speedo, water tem and oil pressure, shift light etc it does have a gear indicator but it isnt very clear so i thought the geartronics was ideal as it would be in my line of vision?
I havnt spent the ££££ so it is always wise to evaluate all the options, next pile of cash is planned for the paint job and body repairs :fear:
Then for all the nice bit's to finish it off......
I cant wait to just get the kit into the shell and for it to sit on it's wheels again, those are the milestones in a project that spur you on to get it done.
Mark
#139 Ade
Ade
    the bogie man
  • 2,357 posts
Posted 16 November 2005 - 03:43 PM
Pete and I considered these for a while but in the end got a good deal on the gauges we have in the cars so left it.
I think it worked out a bit cheaper than stack and looked lovely :D and also included the fuel gauge which stack doesn't.
#140 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 16 November 2005 - 03:52 PM
I havnt go any provision for a tank sender yet as i was gonna run the std. tank to for a while then have a larger version made with a remote filler and sender unit etc at a later date, as z-cars have a neat one in the new type r mini and even stored the battery under the tank. The original tank just about holds 5 gallon if my calcs are correct :D
The gauge thing will be up in the air till im ready to buy them, i have looked at the spa tacho and use a seperate dual digital gauge for fuel andwater temp,oil pressure. By the way, what batterys are you all running and where have you mounted them???
Mark :wales:
#141 Ade
Ade
    the bogie man
  • 2,357 posts
Posted 16 November 2005 - 04:02 PM
Completley none technnical anwser. I bought the smallest car battery I could find :grin: Mines mounted behind the passenger seat ( was the only space I had left) Pete's is mounted on a convienient shelf in front of his engine! Damn him and his spacey pick-up! :tongue:
#142 Dick Dastardly
Dick Dastardly
  • 261 posts
Posted 16 November 2005 - 04:59 PM
The SPA sytem is really really nice, but REALLY REALLY expensive!!
I havn't fitted a battery yet, but have a couple lying around which I trial fitted before paint, along with a securing strap behind the passenger seat. I'd like to use a bike battery though as they tend to be much smaller and lighter, but I don't know whether they'd be up to the job or not. I need advice on this one.
Incidentally, where have you taken/ are you planning on taking, the oil pressure capillary from? Presumably it's an electro-mechanical sender? I've seen some people take it from the inside of the oil cooler mounting bolt, but just wondered if this is the best place or not.
D.D.
#143 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 16 November 2005 - 05:10 PM
i dont know about the R1 but the hayabusa has a oil pressure switch in the block by the fitter so my sender will go in there with the switch and the water temp sender is going as near as possible to the engine as this will give true engine temp reading. Fan switch will be in the radiator.
Mark :wales:
#144 R1minimagic
R1minimagic
  • 4,660 posts
Posted 16 November 2005 - 06:56 PM
DD
I have the Spa system and am very pleased with it. My battery is a lightweight racing one from Demon Thieves (got it as a xmas prezzy off my mum!), not had any problems with it yet, ive had it fitted for 2 years now. It is installed on a small tray in front of the fuel tank.
If you have a carb'd R1 you can use the cylinder head blanking plug as your oil pressure source.
#145 R1minimagic
R1minimagic
  • 4,660 posts
Posted 16 November 2005 - 06:58 PM
PS You can save buckets by getting the dials direct from Spa. I think I saved over £100 on them.
#146 pete
pete
  • 680 posts
Posted 16 November 2005 - 08:11 PM
If you've got reverse then don't go for a bike battery. It's not powerfull enough. I just went for a standard car battery as I have that extra few inches :wink: and i'm not worried about weight. Mounted in front of engine behind bulkhead.
Oil sender is fitted into cylinder head just above and to the left of the exhaust manifold. There's a 10mm bolt that you use to check pressure. We had an adapter made to go from 6mm external thread up to 1/8npt internal with a 1.5mm hole through the middle. The only problem we found was the tendancy to snap off the small 6mm threaded section when we fitted them. Managed to snap 3. Now they are fitted it works fine.
A friend has drilled out the bolt on the oil cooler and had it tapped to accept the sender unit. If you can fit it behind the manifold then I think this is the better way.
Pete
#147 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 16 November 2005 - 09:49 PM
Its now bloody freezing outside so time for tonights up date.....
As i said i have used the templates from minispares website which are printed on 5 peices of paper and then taped them together.
and fixed in place .
#148 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 16 November 2005 - 10:01 PM
and this is what it looks like.......... :P
They fitted mint straight away which has suprised me as they are copy version's of the arches & i made the templates in the first place........... :D
#149 Jackman
Jackman
  • 4,053 posts
Posted 16 November 2005 - 10:03 PM
Very nice. What colour are they going?
#150 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 16 November 2005 - 10:04 PM
And a front view..............
I am not fitting the front arches yet as i have to replace the wings, a-panels and scuttle so no point in chopping them yet.
Mark :wales:
