My engine turns over again (after christmass and no oil pressure and then thinking I'd siezed it). Anyway... there's no oil coming out the pump.
can it be replaced without removing the engine?
Cheers!
Edited by Kernal H, 02 April 2009 - 05:53 PM.
Posted 02 April 2009 - 05:52 PM
Posted 02 April 2009 - 06:11 PM
Posted 02 April 2009 - 06:26 PM
Posted 02 April 2009 - 06:45 PM
have you tried repriming the pump? I believe you poor oil down the hole for the pressure relief valve, then rock the car back and forth with it in gear until the oil goes down into the pump, keep refilling until it doesn't go down any further, and try cranking it again to see if you get pressure.
Posted 02 April 2009 - 09:38 PM
Posted 03 April 2009 - 01:19 AM
Posted 03 April 2009 - 01:39 AM
Posted 03 April 2009 - 08:49 AM
Posted 03 April 2009 - 11:33 AM
Posted 03 April 2009 - 11:56 AM
Posted 03 April 2009 - 05:28 PM
Posted 03 April 2009 - 05:31 PM
Posted 04 April 2009 - 01:12 PM
Posted 04 April 2009 - 01:26 PM
Posted 04 April 2009 - 01:42 PM
