I was just wondering how hard is it to blend new paint into old paint? If you don't know what I mean I'll try and explain it another way
Can anyone help?
Posted 31 March 2009 - 09:15 PM
Posted 31 March 2009 - 09:54 PM
Posted 01 April 2009 - 06:06 PM
Posted 01 April 2009 - 06:14 PM
Posted 01 April 2009 - 06:33 PM
Posted 01 April 2009 - 06:35 PM
Ive blended that colour before, its not too difficult
paul
the way we do it at work is paint what you have to then get some laquer mix it thin and blow it over the edge of the paint until it blends together. when its dry just polish the laquer so it blends in again, we do this is on commercial vehicles so theres probably a diffrent way for cars
Posted 02 April 2009 - 08:24 PM
Posted 02 April 2009 - 08:36 PM
Posted 02 April 2009 - 08:41 PM
Not sure the best place to get paint in your area.
Prep and prime and flat the repairs
Mask the panels off that are being coloured
Polish the original paint with G3 where the new paint will be blended. This will give just enough 'key' for the blend paint to stick
Put 1 coat of colour over the primer
Another coat of colour over that area but make it a slightly larger area
Last coat should be a larger area still but light around the edges without going right upto the masking.
If its direct gloss get a little neat thinner in the gun and lightly dust it over the blend, it will go matt.
If its lacquer finish put the lacquer on in the same way as the colour - getting larger, it could be easier for you to lacquer out the full panel.
Flat and polish.
This is how I have always done it, its hard to explain it, I just do it without thinking
Paul
Posted 02 April 2009 - 08:46 PM
Posted 02 April 2009 - 08:49 PM
Edited by Paul Wiginton, 02 April 2009 - 08:52 PM.
Posted 02 April 2009 - 08:54 PM
Yes, thats what I use, some use G matt by Farecla or scotchbrite, but I think theyre too coarse
Paul
Posted 02 April 2009 - 08:58 PM
Posted 02 April 2009 - 09:00 PM
Posted 02 April 2009 - 09:05 PM
This is what I meant by its hard to explain.
Take a door for example.
The bottom front corner has been repaired.
Mask the panel so the whole skin is exposed.
Prep prime and flat the repair - keeping it as small as you can.
G3 the whole panel.
Put the first coat of colour on so it just covers the primer, then the second coat a bit bigger and the 3rd a bit bigger still. You can lacquer the whole panel if you want.
Paul
