Thinking about it again what I said might only apply to painted on plates, not stickers. I'd have to look it up. I'm fairly sure yours does need to be vertical though, it's only the historic type plate that you are allowed not just any old thing you want. You say that you can't see the registration when you are close to the vehicle which pretty much means it's not permitted, there are rules about where it must be clearly visible from.
Lots of people get away with breaking the law, doesn't mean you will and it doesn't make it right. Your car already has a producer recorded against it for mis-represented registration so it may be on a hot list. Do you know that if you get issued three seperate warning for this you go to court and get a £1000.00 fine rather than just a fixed penalty. If they decide that you've been doing it deliberately despite multiple warnings they can take the registration off you (that is normally done if you have a number that you are represnting as a word or a name though). Then you have to go through getting your car re-registered and from the sound of it yours wouldn't be likely to pass the VIC check needed. At the very least you'd loose historic tax status on the car, at worst they might crush it.
Rear Fog Light Law
sean1380
, Mar 29 2009 01:32 PM
18 replies to this topic
#16
Posted 30 March 2009 - 04:47 PM
#17
Posted 30 March 2009 - 06:46 PM
are u a man of the law?
the other producer was on my 1st mini bk wen i was 17,
think the cops are watchin my current vehicle tho as where we all sit they come up n park accros from us,write down everyones registration then leave after
5min the come back later on,drive up with no lights on n stuff its really weird,cant go anywhere without feeling watched is there anything i can do about that?
well its an historic plate is it not being black and white and being a historic vehicle so am i not allowed?
ill just av too see what happens n if anythings said ill put it on the bonnet like everyone else
cheers tho for the heads up
#18
Posted 31 March 2009 - 12:19 AM
No I'm not but several of our members are.
I really can't work out what most of the rest of your post is meant to say I'm afraid.
#19
Posted 31 March 2009 - 03:36 PM
im on about the black and white reg refering to your previous comment
doesnt matter
doesnt matter
