1994 Carb Emissions Failed Mot
Posted 27 March 2009 - 09:10 PM
Please give your topic a title that quickly describes your problem. Just putting 'Help my Mini doesn't work' is useless to anyone trying to help.
Model: open classic
Year:1994/5 L-reg
dad took the project mini for its mot today.. when i came back from work they have failed it on emmisions. Looks quite harsh to me; its got a carb and the limits for c.o are 0.75 on idle and 1.09 fast idle. so its failed on those as well as something called lambda.
am i right in thinking that a carb mini will never reach these limits? and they have tested it if it were injection?
can i complain to vosa if i'm right?
Any non-standard parts that might be involved with the problem? no its standard.
Posted 27 March 2009 - 09:19 PM
Lambda sensors were only fitted to injection cars.
I dunno how you contest a MOT failure, but there must be a way, and you seem to have strong grounds.
Posted 27 March 2009 - 09:24 PM
dave
Posted 27 March 2009 - 09:30 PM
thanks lads
Posted 27 March 2009 - 09:39 PM
1994 was the change over year i think so that may have caused some confusion.
Before causing hell, point out the carb and say "You've done the wrong test, do it again"
let us all know what happens.
Edited by huntface, 27 March 2009 - 09:39 PM.
Posted 27 March 2009 - 10:32 PM
Seems a strange error for a MOT station to make.
"Blimey guvnor, what's that thingy down the back there? He's gawn and left 'is thermos in there!"
Posted 28 March 2009 - 04:25 PM
Edited by Dan, 28 March 2009 - 04:25 PM.
Posted 28 March 2009 - 06:39 PM
Posted 28 March 2009 - 09:34 PM
http://www.motinfo.g...m3s07000306.htm
The "Basic Emission Test" is a sort of fast track (quick) test using set limits which, which if met by any car is an automatic pass. In your case the chances of passing this are slim, although I have to say your CO readings are very low.
Having failed the BET test the tester should then perform a full CAT test using limits in the analyser database or the booklet provided by VOSA. If a match cannot be found then your car should be tested to lower limits i.e. 3.5%co and 1200ppm hydrocarbons. Please study the Flow diagram in the link below and take particular note of NOTE 2 . If for any reason your engine code cannot be read then no match will be able to be found (wink)
http://www.motinfo.g...m3s07000307.htm
I realise this is pretty much what Dan has said, but I do not have your exact vehicle details or the emission limits book in front of me, nor would it be right to comment without seeing the full analyser printout or the details of your car. I would advise you to familiarise yourself with what is stated in the links, which are taken from the testers manual, perhaps even print them out and when you see the tester ask him to explain which test standards have been applied and show you the match in the database. As stated in a previous post you can ask for an appeal form at the test station. This usually involves filling out a form and you will have to pay the full fee again and have your car retested at a neutral station in the presence of VOSA area inspectors. The test fee is refundable if they find in your favour, but it's a can of worms you would be best leaving the lid on if possible.
Edited by tommy13, 28 March 2009 - 09:49 PM.
Posted 28 March 2009 - 11:50 PM
