Tap For Crank
162 replies to this topic
#1 jn1702
jn1702
  • 168 posts
Posted 27 March 2009 - 03:08 PM
I need a tap to clean up the thread in the end of the crank( flywheel bolt) what thred size is it and where can I get one thanks
#2 Big_Adam
Big_Adam
  • 7,435 posts
Posted 27 March 2009 - 03:21 PM
What the cheese is with all the white space?
Anyway, if I remember the crank thread is a silly very old very odd standard. Think the few people who have one is Guessworks and he paid a sum for it.
I shall have to search!
#3 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 27 March 2009 - 03:25 PM
I dunno - but I can't edit it out!
#4 mike.
mike.
  • 6,176 posts
£120: http://www.minisport...TOLITD6049.html
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 27 March 2009 - 03:28 PM
Yeah, I have one somewhere, but bug**red if I know where....
But if you want one for keepsies, can get you one for considerably less than Minisport want for one... IIRC I paid about £50 notes for mine to be made, but was considerably cheaper than stripping down an engine and replacing the crank.
#6 *DJH*
*DJH*
  • 4,972 posts
Posted 27 March 2009 - 03:30 PM
5/8 16uns :) i had one a while ago and old it
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 27 March 2009 - 03:32 PM
They will always cost a lot more than most taps do. I think most tool shops will charge between £80 and £110 for them at the moment but they're almost guaranteed to be a special order. I seem to remember it's 5/8 Unified Extra-Fine or something like that. Where did you get one made for £50.00 GuessWorks and how many decades ago was that? :teehee: :)
Edited by Dan, 27 March 2009 - 03:40 PM.
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 27 March 2009 - 03:39 PM
Ah yes that's right, it's Unified Special (UNS) not UNEF. UNEF is 24 TPI at 5/8", that would be ridiculous.
#9 DaveRob
DaveRob
  • 703 posts
Posted 27 March 2009 - 03:46 PM
A 'respected engine builder' in Leicester told me to use 5/8 UNF BUT 16 tpi ........ thats what he told me it was.... 5/8th unf is normally 18TPI
Rob
#10 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Went to my local engineering shop, and asked them to get me one, quick ring to the supplier, 2 days later freshly cut tap in hand... was about 4 years ago...
#11 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 27 March 2009 - 03:48 PM
Rob
That's exactly what a 5/8 16UNS is :)
If there was enough of a demand for them I'd get'em to run a few off, which would make them cheaper...
Edited by GuessWorks.co.uk, 27 March 2009 - 03:50 PM.
#12 DaveRob
DaveRob
  • 703 posts
Posted 27 March 2009 - 03:51 PM
Id have one........... maybe the start of a list here...lol
Rob
#13 Nightrain
Nightrain
  • 976 posts
The Exact size is 5/8" WF (Whitworth Fine)
#14 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 27 March 2009 - 03:55 PM
Exactly, Unified thread forms all use the same angles and peak and valley shapes. UNF is a certain pitch, UNEF is another pitch and UNC is another pitch again but if you want something that doesn't fit into a standard pitch it's a special. That's what UNS means. It's not UNF specifically because it isn't the same pitch as UNF, it's UNS.
I'd be interested if you do.
No it isn't, Whitworth threads use a different peak and valley shape from Unified and a different angle. Whitworth is 60 degrees with a radius at both the peak and the valley, Unified is 55 degrees with a radius at the valley and the peak cut square (which is exactly the same as Metric). Is there such a thread as Whitworth Fine? There's BSF but I've never encountered BSWF and I deal in Whitworth quite a bit considering it's an obsolete threadform.
Edited by Dan, 27 March 2009 - 04:03 PM.
#15 GraemeC
GraemeC
  • 7,435 posts
Posted 27 March 2009 - 04:11 PM
Never come across Whitworth Fine before - certainly not in any of my engineering guides. Whitworth is a coarse thread type under the British Standard family, BSW, BSF, BSCY, BSP, BSPT, BSB which have a 55 degree thread angle.
The UN range is the adopted American standard that uses a 60 degree thread angle.
It would be odd for the crank to be the only part of the car to use BS threads when the rest were UN (apart from odd small stuff that used BA).
(I was writing this as Dan posted!)
Edited by GraemeC, 27 March 2009 - 04:12 PM.
