hiya
i have just started to notice that i get some clicking noises coming from the front end of the car when on full lock whilst putting some power to the wheels.
the wheel bearings and ball joints were all renewed about a month ago for the MOT which it sailed through. its all running nice and smooth as far as i am aware.
what do you think could be causing this noise?
cheers
adam
Clicking On Full Lock
stardude
, Mar 23 2009 05:06 PM
4 replies to this topic
Posted 23 March 2009 - 05:06 PM
Posted 23 March 2009 - 05:15 PM
Sounds like classic cv joints on their way out. Many a mini used to be scrapped for this but its not that bad a job to fix.
Posted 23 March 2009 - 05:25 PM
if thats what it is then thats good, as i can replace them myself
i have just had a look and noticed that on the drivers side CV gaiter it has become a bit loose over the cv and has lost quite a bit of grease
so i will get some CV grease, grease it up and see if that helps.
if not then i will just change the CV.
cheers
any other ideas??
cheers
any other ideas??
Posted 23 March 2009 - 07:19 PM
any other ideas??
I agree with Mister Bridger's diagnosis of CV joint. Clicking in hard lock is a sure sign it this...
Copied from haynes:
Clicking or knocking noise on turns (at slow speed on full-lock)
- Lack of constant velocity joint lubricant, possibly due to damaged gaiters (Chapter 8).
- Worn outer constant velocity joint (Chapter 8).
Ryan.
Posted 23 March 2009 - 07:27 PM
ahh so the lubricant thing is obviously what has caused it!!
will get straight onto that!!!
cheers guys
adam
cheers guys
adam
