Engine Ticking Noise
19 replies to this topic
#1 chappy
chappy
  • 1,253 posts
Posted 22 March 2009 - 01:06 PM
Model: city
Year:1992
Hi all,
well as of 2 days ago the engine seems to be 'ticking' more, i can hear it more on the inside of the car, and sounds a bit like a ropey old diesel car.
I have recently done the 'intensive carb clean' with redex where you pour half the bottle into the air intake slowly, and it clears all the crap of the inside, but i don't think that would have made it start this noise or any infact.
the only things i can think of are the rocker gaps, or the fan catching.
just wondered if anyone else had the same problem and knew what it was
sam
oh, and it only seems to be at low revs.
Edited by chappy, 22 March 2009 - 01:10 PM.
#2 chappy
chappy
  • 1,253 posts
Posted 22 March 2009 - 03:06 PM
bump
#3 luke6040
luke6040
  • 449 posts
  • Local Club: na
Posted 22 March 2009 - 03:42 PM
My car started doing this a few yrs ago and still is, i never found the problem , but its still going strong. Hopfully somone can shed some light though.
#4 Pauly
Pauly
  • 4,213 posts
Posted 22 March 2009 - 08:16 PM
Check your rocker clearences, failing that it could be the timing chain tensioner.
Paul.
#5 chappy
chappy
  • 1,253 posts
Posted 22 March 2009 - 08:20 PM
the timing chain tensioner is on the fan side of the engine right?
thanks
sam
#6 Pauly
Pauly
  • 4,213 posts
Posted 22 March 2009 - 08:21 PM
Yes. Will need to take the cover off obviously, after taken radiator out etc.
Paul.
Edited by Pauly, 22 March 2009 - 08:22 PM.
#7 chappy
chappy
  • 1,253 posts
Posted 22 March 2009 - 08:23 PM
oh yay...
#8 luke6040
luke6040
  • 449 posts
  • Local Club: na
Posted 22 March 2009 - 08:25 PM
thanks
sam
Ye, if your ticking is like mine it will be on the other side?
#9 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 22 March 2009 - 08:42 PM
With it ticking over, loosen off the two rocker cover bolts and try to 'move' the cover around and see if it stops?
#10 chappy
chappy
  • 1,253 posts
Posted 22 March 2009 - 08:57 PM
i'll give it ago,
but the noise seems to happen when pulling off and accelerating harder in 2nd. (if that makes sense?)
sam
#11 Nightrain
Nightrain
  • 976 posts
Posted 22 March 2009 - 09:17 PM
i'll give it ago,
sam
Well from that description sounds like it's pinking, check the bob weights etc in the dizzy. Probably gunked up and not springing back correctly. So remove the dizzy, strip the points and base plate out, so you can see the bob weights. Then hold the shaft at the bottom, then turn the rotor arm end whilst looking at the bob weights. You should see them moving outwards as you turn the rotor arm end, do they move relatively easily and spring back quickly ? If they don't you want to clean and re-oil them.
#12 chappy
chappy
  • 1,253 posts
Posted 22 March 2009 - 10:26 PM
would this be making a ticking noise though?
the ticking picks up speed as the car does too, (if that helps at all)
sam
#13 Madmax
Madmax
  • 2,638 posts
  • Local Club: Grimsby & Louth MOC
Posted 22 March 2009 - 10:31 PM
does it sound like this?
#14 Nightrain
Nightrain
  • 976 posts
Posted 23 March 2009 - 12:43 AM
Pinking can be described as a ticking noise by some.
#15 chappy
chappy
  • 1,253 posts
Posted 23 March 2009 - 10:25 AM
kinda, but not so loud, or constant.
as i said above, i did the redex 'intensive carb clean' this wouldn't have done anything would it? :thumbsup:
sam
