Charge Cooler Info/help
#16
Posted 25 April 2009 - 03:29 PM
In reality all forced induction engines will benefit from intercooling. The reason I mentioned turbo setups is to illustrate that additional air cooling would be of benefit as supercharged air tems are higher.
It is a fact that if you want maximum power then a turbo is the thing to have. The maths shows this and so do all the results I have seen. There are of course benefits to supercharging, such as more low-down power.
#17
Posted 25 April 2009 - 06:41 PM
Anyway, I know realise that the is no way of have and inter/charge cooler on this supercharger set up I have. But you can get the water jacket this that does cooler the charger itself.
#18
Posted 28 April 2009 - 10:29 AM
My problem is that you keep saying that the setup you have does not need any extra cooling. And your reason for this is that your inlet tube is icing up.
no where have i said that the set up does not need any extra cooling
if you read my posts i state that unless running high boost etc you dont need it
i have not stated that you dont need it due to inlet icing up all i have stated is that it ofsets some of the heat produced to the compressing of the inlet charge
#19
Posted 28 April 2009 - 11:36 AM
Isn't specific heat capacity a constant related to mass? I think that means a temperature reduction, of say 10 degrees, will dump more heat from a denser (compressed) gas. Of course the biggest bug bear is the fuel.
#20
Posted 04 May 2009 - 04:28 PM
#21
Posted 08 May 2009 - 05:46 PM
VMax Charger Cooler.
did it make any difference on yours?
#22
Posted 08 May 2009 - 05:52 PM
Same here
#23
Posted 11 May 2009 - 12:47 PM
Honestly I am not sure what difference it made. It should reduce heat from the charger, so general engine bay temp maybe a little lower, but if you are looking to reduce coolant temp, then fit a secondary radiator IMO.
#24
Posted 11 May 2009 - 02:43 PM
Do the mpi kits run a single belt around the crank/waterpump/alternator/charger?
#25
Posted 30 May 2010 - 09:43 PM
sorry for the off topic question, but in that picture, your charger on the MPI engine looks to be more towards the drivers side than the carb'd installations, which would imply that the charger is running off the standard mpi bottom pulley, also, you don't seem to have the upper tensioner wheel on the charger that the carb'd setup's run.
Only a year late, yes the MPi runs a single belt.
#26
Posted 30 May 2010 - 10:47 PM
#27
Posted 31 May 2010 - 07:58 AM
Having a water cooler as vmax (plumbed of the engine im asumming). water temp at 88c dose not add up to me?
I might be getting it all wrong?
JOE
#28
Posted 31 May 2010 - 08:26 AM
Personally I can't see that charge cooler working efficiently. Optimum ACT's (Air Charge Temperature) is 39 degrees. Don’t be fooled that the low the ACT’s the better performance is obtained...
graham ,just to be sure ,are you saying you can prove that any air temp below 39 degrees c is bad for power ?
#29
Posted 31 May 2010 - 08:38 AM
Temps below 39 degrees will be 'ok', but to get the best power you need to stay as close to 39 degrees as possible.
#30
Posted 31 May 2010 - 08:40 AM
I have kept an eye on charge cooler temps (only on the outside casting) & the temp has never gone over 55c.
JOE
Is your charge cooler using its own water supply, or using the water from the engines radiator?
