How Do You Get Rid Of Fish Eyes?
Posted 15 March 2009 - 07:05 PM
iv recently painted my 1990 mini city with mipa 2k solid color paint and i am having terrible problems with fish eyes. iv been told that they are caused by silicone on surface and i should take care when degreasing but i have degreased 3 times and still i get them so does anybody know how to get rid of them once there on the panel (i presume sanding) and how to stop them coming back?
regards Chris.
Posted 15 March 2009 - 07:15 PM
Posted 15 March 2009 - 07:20 PM
thanks 4 that copper al have to try it do you no how to produce dry spray as i have forgottenhave you tried flatting off the suface and dry spraying over it to build it up? Think it is caused by silicone/ polish left on the surface.
regards
Posted 15 March 2009 - 07:28 PM
Its worked for me in the past.
Posted 15 March 2009 - 09:26 PM
depending how many u get, if a solid colour you can of course dob them in with a small brush and wet flat and polish
dave
Posted 16 March 2009 - 06:53 PM
As said all you can do is flat them out and repaint.
You can buy anti silicone drops to put in your paint too, with varied success.
Panel wipe generously and with lots of clean cloths too.
Posted 20 March 2009 - 08:40 PM
Posted 20 March 2009 - 08:44 PM
Not really a suggestion, just curious?
Posted 21 March 2009 - 12:17 AM
as for your current paint, it will need taking back a bit before spraying again as silicone is virtually impossible to remove completely i'm afraid.
Posted 21 March 2009 - 06:45 PM
Get a very fine pointed brush and when your last coat has gone tacky you can blob them in out your mixing pot, give it another 2-3 minutes and then your next coat.
Once nibbed and polished you cannot tell.
Posted 21 March 2009 - 06:47 PM
Silicone/ fisheye marks dont come from older paint or something underneath, thats a reaction.. which barcoat stops.If it were contamination under the paint would bar coat help?
Posted 24 March 2009 - 06:05 PM
regards chris.
Posted 08 April 2009 - 10:28 PM
Basically I been re-spraying the 25 and lacquering it this time, which in parts considering under the circumstances I’m doing it, hasn’t turned out too bad. I did how ever have a load of runs down both sides, more down to doing it in a cramped garage. So doing a side at a time so I have a bit more room to play in I’ve sanded the runs back, gone back over with silver and re-lacquered, with no more runs this time.
The problems I’ve got now is I accidentally dropped something on one of the front wings, which although the paint was dry, had been left for 2 days it was still soft with it being enamel based. So I’d chipped and scratched the paint, but what with it being a light metallic silver, meant I had to sand it back again and go back over it, etc.
The problem I’ve been having is every time I’ve gone to spray the sliver base coat it starts off fine, but these clear blobs keep appearing, I’ve mixed up a new batch of paint and cleaned out the gun in the hope of it being some of the left over lacquer possibly mixing and causing the reaction, but with no difference.
So if I’ve got this right, and this is getting frustrating having to keep re-painting the same panel, that the reaction is caused by the panel not being completely spotless before spraying?
