Stuck Piston Rings
5 replies to this topic
#1 12oss
12oss
  • 46 posts
Posted 15 March 2009 - 04:02 PM
hi there does anybody know how to free stuck piston rings without taking the engine to bits.
#2 tog77
tog77
  • 161 posts
  • Local Club: maun mini's
Posted 15 March 2009 - 04:12 PM
yes..take the head off,turn the engine till all the pistons are half way..fill the bores with redex then let it stand for a week..usually works..
tog 77...
#3 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 15 March 2009 - 05:45 PM
In what way are they stuck?
#4 12oss
12oss
  • 46 posts
Posted 15 March 2009 - 08:10 PM
the engine was taken out about 7months ago put out side but coverd over so think they got stuck do to this
#5 wile e coyote
wile e coyote
  • 1,230 posts
Posted 16 March 2009 - 12:56 AM
Hesitate to suggest this - but as engine is out of the car - if more sedate methods fail - put 50 ml petrol through the plug holes - assuming pistons not at top of bores & light it - when just burnt turn crank back & forth gently - before it cools pop some fresh engine oil / diesel mix down the bores and leave overnight - bit dramatic but usually works.. be very very careful setting fire to things though!!!!
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 16 March 2009 - 07:29 AM
So you actually mean the engine is seized... and the only way that happens is rust...
This means the ring is useless and the bore is damaged.
