Inner Cv Joint Stuck To Axle
Posted 10 March 2009 - 10:15 PM
Year:1994
Description of problem (please be as in depth as possible):While attempting to replace the outer CV joint gaiter, the axle would not come off the inner CV joint. The outer joint came off the axle instead. Finally pulled the axle with the "star" of the inner joint attached and can not get it off. I drilled 1/2 inch hole on the back shell and have tried hitting it through the hole and now I am using a puller, as in the photo, to try to get the axle out. I added some penetrating oil to see if it helps. Any suggestions? Or, should I start looking for a left axle?
Any non-standard parts that might be involved with the problem?As far as I can tell the parts are original and not modified.
Thanks.
Posted 10 March 2009 - 10:46 PM
There is a circlip on the splined end of the shaft.
It will come off fairly easily once moved initially.
Using the puller is pulling the centre of the CV joint against itself so will not come off that way.
Posted 10 March 2009 - 11:24 PM
Posted 10 March 2009 - 11:26 PM
Posted 11 March 2009 - 12:09 AM
Thanks again for the suggestions and any additional ones are very much welcome!
Posted 11 March 2009 - 12:58 AM
If not try dipping it in penetrating fluid overnight then set too with the hammer and chisel.
Be careful if you decide to cut it off with the dremel as you may damage the splines.
I have just done both mine on my GT and they came off very easily.
Posted 11 March 2009 - 01:11 AM
Edited by sprintmini, 11 March 2009 - 01:12 AM.
Posted 11 March 2009 - 01:26 AM
Posted 12 March 2009 - 08:23 PM
Thanks everybody for the help.
Posted 12 March 2009 - 08:38 PM
with these i normally hold the drive shaft in one hand and use a big copper mallett and knock the joint off with the other hand, i've never had a problem getting them off like that.
thats what i do,except with a large rubber mallet
