Just purchased 1971 mini near original condition, is there an easy way of telling if it has been converted to running on unleaded petrol.
Thanks in advance for any info.
Edited by Green-Chameleon, 10 March 2009 - 09:18 PM.
Posted 10 March 2009 - 09:14 PM
Posted 10 March 2009 - 09:16 PM
Posted 10 March 2009 - 09:58 PM
Posted 10 March 2009 - 09:59 PM
Edited by Verns_Playmate, 10 March 2009 - 10:06 PM.
Post from this thread removed as requested
Posted 11 March 2009 - 09:31 PM
Posted 11 March 2009 - 09:44 PM
Posted 11 March 2009 - 10:44 PM
Edited by Dan, 11 March 2009 - 10:44 PM.
Posted 11 March 2009 - 11:09 PM
Adding a bar of lead will do nothing to your fuel. Nor will adding a bag of lead shot. Nor will adding those inline fuel lead 'filter' type canisters. Lead does not dissolve into petrol, therefore it does not add lead to unleaded petrol.
The ONLY way to run unleaded petrol through a head that hasn't been converted/designed to run on unleaded petrol is to use a liquid additive such like Castol Valvemaster (or Valvemaster + for an octane boost as well). This will actually mix with the petrol and allows the necessary additives to protect the valve seats in your cylinder head.
As for running unleaded petrol in a leaded cylinder head. If you have been using leaded petrol for a while it builds up a layer of coke on the valve seats. Once you start using unleaded petrol it begins to eat away at this layer of coke. This can take months, it can take years, but once this layer of coke has been consumed the unleaded petrol will begin to eat away at the valve seats. After a while this destruction will mean you start to lose compression on the engine, and when it gets really bad will cause problems with idling, fuel consumption and general tuning of the engine.
Please do not continue to give out advice that states you can just add solid lead to the fuel. You really can't. You make think that it is just our opinion that this advice is wrong, but it is an opinion that has very good and deep foundations. Rover, kings of cost-cutting, spent many thousands of pounds researching the affects of unleaded petrol on the A-series engine and in the end they decided to add the hardened valve seats. If they could have added a 'lead canister' to a fuel line which would have become a service part they could have made money from then they would have done.
Posted 12 March 2009 - 08:03 AM
Well I stand corrected and I would Like to appoligise as this was told to me in good faith many years ago when the old 4 star was taken off the pumps by a top physics teacher ..........
Posted 13 March 2009 - 10:28 PM
Posted 23 March 2009 - 01:04 PM
Posted 23 March 2009 - 01:26 PM
Edited by bigmotherwhale, 23 March 2009 - 01:29 PM.
Posted 23 March 2009 - 01:30 PM
Posted 23 March 2009 - 01:34 PM
Edited by bigmotherwhale, 23 March 2009 - 01:37 PM.
Posted 23 March 2009 - 04:36 PM
