Replacing Front Indicator Bulbs
12 replies to this topic
#1 niko-time
niko-time
  • 58 posts
Posted 10 March 2009 - 09:05 PM
Model: Rover Mini Mayfair
Year: 1991
Hi, I was told I needed to replace my mini bulbs for my indicators as they were apparently running out. I replaced the back ones easily with soem halfords ones but the front I am having more difficulty with as I am not sure how to get the current lamps out. I got one out by twisting and pulling but I think I did it wrong as the bulb doesn't have the bottom connector on the bulb I am replacing it. I fear I have yanked it out, as being more careful with the other one hasn't worked.
What can I do to fit them? Or does it have to be a mechanic jobby.
#2 yorkshirechris
yorkshirechris
    11.11.11
  • 3,873 posts
  • Local Club: www.lcmoc.com
Posted 10 March 2009 - 09:11 PM
They may be slightly rusted in, they come out the same as the others they're sort of a bayonet type, give them a twist and a pull and they should come out no problems.
Pair of long nose pliers might be handy to get the remains out of the one you've already attempted :w00t:
If the unit they go into is rusted it might be worth ordering a new set from minispares and wiring them in yourself if you feel confident enough, it's only a half hour job really and doesn't require any knowledge.
#3 daemonchild
daemonchild
  • 2,341 posts
  • Local Club: Unknown
Posted 10 March 2009 - 09:17 PM
As Chris says, but try to push in, then turn (clockwise off the top of my head), then the spring will push it out for you.
#4 niko-time
niko-time
  • 58 posts
Posted 10 March 2009 - 09:19 PM
Great guys, I shall try that after the liverpool game (3-0 so far, completely dominating, hurrah), hopefully shall work. Thanks a lot.
#5 daemonchild
daemonchild
  • 2,341 posts
Posted 10 March 2009 - 09:48 PM
Just be careful if you've got broken glass in there from your previous escapades! :w00t:
#6 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 10 March 2009 - 10:25 PM
#7 matt615
matt615
  • 923 posts
Posted 10 March 2009 - 10:32 PM
Bulbs do not 'run out'!
Occasionally a bulb will blow and you'll need to replace it. I can't see any reason why you'd suddenly need to change all your bulbs though.
#8 daemonchild
daemonchild
  • 2,341 posts
Posted 11 March 2009 - 08:48 AM
I missed that the first time I read the post!
Perhaps he has clear lenses and the bulbs have faded?
But otherwise, it sounds like someone had some bulbs to sell! Lol.
#9 niko-time
niko-time
  • 58 posts
Posted 12 March 2009 - 04:39 PM
Ah, I was just told by someone who used to own a mini that the indicating was speeding up so I should change the bulbs. It has progressed to simply not flashing when I indicate, just having the solid colour.
I failed to get out the front ones anyway, shall have to take it to the garage to see if he can fix my shortcomings!
What could the error be instead then?
#10 JD8891
JD8891
    Previously known as Soul_racer
  • 379 posts
Posted 12 March 2009 - 09:13 PM
It is prob the flasher unit under the dash by the steering column.
JD
#11 niko-time
niko-time
  • 58 posts
Posted 13 March 2009 - 04:23 PM
flasher unit is indeed, can I get a replacement from somewhere like halfords?
Cheers, don't I feel like a fool! Never mind, can't hurt to replace some rusty old bulbs
#12 JD8891
JD8891
  • 379 posts
Posted 13 March 2009 - 04:26 PM
Yeah can get flasher units from halfords but in my experence they dont last very long, better of with the unipart ones.
JD
#13 matt615
matt615
  • 923 posts
Posted 13 March 2009 - 07:33 PM
Agreed. Halfords flasher units are crap.
