Mph = Rpm
9 replies to this topic
#1 Minisniper
Minisniper
  • 380 posts
  • Local Club: Market Drayton Mini Club, Minis On A Mission.
Posted 09 March 2009 - 04:09 PM
Hiya
I have a question for those of you who have a 998cc Automatic.
I'm trying to work out from my rev counter and speedo what speed I should be doing to what revs on a flat road, example 50mph = 3000rpm which to me seems a little high, I would be interested to hear from those of you who have a 998cc Automatic. :thumbsup: :o ;)
Looking forward to your replies. ;) :)
#2 Ethel
  • 25,922 posts
Posted 09 March 2009 - 04:34 PM
You can use a computer gear calculator Guessworks, Winsu etc. Just tap in your tyre size and diff ratio (3.27:1?)
#3 Ouster
Ouster
  • 2,986 posts
  • Local Club: Looking
Posted 09 March 2009 - 04:49 PM
In my 998cc manual, I'm doing 4000 revs at 70.
#4 mini mark
mini mark
  • 876 posts
Posted 09 March 2009 - 04:56 PM
ye mines a little under 4000 at 70 .
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 09 March 2009 - 04:58 PM
Auto's are strange beasties which have odd final drives, but also, because there is no direct drive between the crank and the gearbox ( there's a fluid torque convertor in the way ) there will never be a direct comparison between what your right foot is doing to the engine RPM and the speed of the vehicle.
The auto's also had a number of final drives, not only the 3.2, but also a 2.7 on the "E"conomy models and a 2.6 on the some of the 1275 units.
#6 Minisniper
Minisniper
  • 380 posts
Posted 09 March 2009 - 05:03 PM
Hiya
Thanks for the replies but mines an auto as I said in my post and from what I can gather what you get in your manuals doesn't necessary follow with an automatic as the ratios in a manual gearbox and an automatic gearbox are different.
Looking forward to more replies.
#7 Minisniper
Minisniper
  • 380 posts
Posted 09 March 2009 - 05:10 PM
Thank you for your reply Guessworks however what you have put here all sounds very good and complicated and to be honest has just gone straight over my head. What I am trying to find out is if I'm doing 50mph on a flat road at around 3000rpm in a 998cc auto with only 15,000 miles on the clock would this seem to be normal/reasonable? ;)
I wish I had as much knowledge as you do or as you seem to have on this site :thumbsup: :o ;)
#8 Bristolboy
Bristolboy
  • 291 posts
Posted 09 March 2009 - 05:18 PM
about 85mph @ around 4300rpm, but mine is a 998 manual
Bb
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 09 March 2009 - 05:28 PM
What I am trying to find out is if I'm doing 50mph on a flat road at around 3000rpm in a 998cc auto with only 15,000 miles on the clock would this seem to be normal/reasonable? :thumbsup:
Yes
But the point about there is no hard physical connection between the crank and the gearbox in a Mini auto is an important one... unlike a manual where there is being the clutch. This why you can 'coast' along for a while in an auto at an absurdly low rpm and going down hill, but when you come to go up a hill, the engine has to 'over-run' the gearbox to get up...
I'm trying to think of an easy to understand analogy for the torque converter but it's difficult... something like a water wheel comes to mind but an example escapes me
#10 Minisniper
Minisniper
  • 380 posts
Posted 09 March 2009 - 06:16 PM
What I am trying to find out is if I'm doing 50mph on a flat road at around 3000rpm in a 998cc auto with only 15,000 miles on the clock would this seem to be normal/reasonable? :o
Yes
Hiya Guessworks.
thanks for the reply, my partner has an automatic pajero and he's just replaced his torque converter so I know what they look like and you're right they do look like a water wheel and I do understand abit about being no physical contact between the engine and the gearbox so thanks again for your help. :thumbsup:
