As with many mini owners i've seen post this topic before, but i still need specific information. My hazards don't work, when the switch is half way down the switch flashes rapid with no response from the actual indicators, fully down and no lights are on but the relay buzzes (rather than clicks) strangely this seems to be the relay for the indicator as pose to the hazard relay?? ie the relay under the steering column, looking at other posts the hazard relay is supposedly in the engine bay next to the wiper motor but all i can see is a four pin relay not the two pin one. Does this sound like someone has wired the two together? I' ve swaped out the hazard switch, no joy, and the indicator relay but this seemed the wrong type and burned it self out
To summarise hazards - nothing but funny noises from indicator relay. Indicators - go left but not right (even though the relay clicks for right without lights, save the wing light ticks v. dimly)
