Project Rewind
#16
Posted 02 June 2009 - 08:09 PM
Most of the work is been around getting the back/boot sorted out, added filler to cover the welding work.
Removed the side windows and the 4 layers of paint, painted the edged and corners that are hard to get to using an artist brush. Should be sanding and applying the second tomorrow.
Have finished painting the rear bins and wheel arches.
Finally started on the wiring and have managed to prep some of the looms for the dash (Jupitus if you are reading this, expect a PM in the next few days if I get stuck).
Time for dinner, better go before the wife decides Albert has to go.
#17
Posted 07 June 2009 - 07:21 AM
Having tested Rusto-leum on the small part of the body it looks good, so out comes the roller to do the rest of the side, hopefully some pics later on today (subject to the heavy rains forcasted for today).
#18
Posted 07 June 2009 - 09:25 AM
#19
Posted 07 June 2009 - 10:33 AM
#20
Posted 15 June 2009 - 11:06 PM
nice work so far how difficult is the edead stuff to work with im planning on putting it everywhere on my car once the welding and respray is done
It is very easy, simply peal the plastic and stick it on. I am using a wall paper roller to make sure they stick nicely. One advice, cut the to fit roughly to the area, stick it on then cut the corners.
More pics to come in the next couple of days with eDead everywhere (subject to weather).
#21
Posted 15 June 2009 - 11:07 PM
That's starting to look much better! Can't beat a lot of solid metal going in to get your spirits up! You sure about de-bumpering? Always looks to me like rust has been cut out and smoothed over...maybe that's just me though! Whatever you choose - it's coming together well!
I know what you mean, we did replace the rear of the boot with new panel but I kind of like de-bumped minis, although is alot more work to make sure is all nice and smooth.
#22
Posted 16 June 2009 - 07:44 AM
Left hand side (you can just about see the inside after 4 coats)
IMG_2859.JPG 423.33K 66 downloads
Back of the car after 2 coats, already has a good shine:
IMG_2857.JPG 619.71K 44 downloads
Right hand side (tight angle had to take that way):
IMG_2861.JPG 321.46K 53 downloads
I am thinking about remove the rear and front wheels/dampers and doing the inside of the arches with couple of coats. I might just to that this week.
#23
Posted 22 June 2009 - 05:34 AM
Right, as promised here are some pics of the newly painted panels (not the whole car yet). It is pretty amazing, it took around 300 ml of paint and 200 ml of thinner and got 2 coats on the sides and the back (had to through a small amount away). So far good results, I will be flattening and painting again today, hopefully by the end of the week should have 4-5 coats on there and then leave it for a month to settle before lacqure and polish.
Cracking results...watching this thread with great interest and keep up the goo dwork.
BM
#24
Posted 16 September 2009 - 07:34 PM
Have done a fair bit since the last update, the body paint work is not complete and flattened back. I have stripped the roof and painted while (pics to follow), last coat went on today. I removed the entire headlining and should be putting the new one in there tomorrow.
Built a new dash with a different design to go in there, it was nightmare since you can not simply divide the car in 2 halfs, each side has slightly different measurments.
All the wheels have been stripped and grinded, ready for polish now. I have not changed the tyres as yet since I have not decided if I should carry on running the car on the 5.5X12 or 7X13s.
All things going well (specially the wiring), I should have it completed by this weekend and ready for MOT next week.
Will add loads of pics tomorrow with the details.
#25
Posted 18 September 2009 - 07:32 PM
#26
Posted 19 September 2009 - 08:02 PM
Web01.jpg 512.59K 17 downloads
If yes I need your help
Interesting way of connecting the wires, I am surprised it did not catch fire :
Web04.jpg 509.77K 14 downloads Web05.jpg 443.69K 5 downloads Web06.jpg 322.9K 8 downloads Web07.jpg 407.8K 7 downloads
Here is the garden turned into a paint shop:
Web10.jpg 464.1K 9 downloads Web11.jpg 307.81K 7 downloads Web12.jpg 642.87K 6 downloads
I will get some of the car tommorow.
Any ideas, how to clean the rust on the break discs, should I just sand it with 320g?
Web13.jpg 487.41K 7 downloads
Edited by Hekmat, 19 September 2009 - 08:15 PM.
#27
Posted 20 September 2009 - 12:20 PM
You have the same trampoline as us too!
For the disks, I would be tempted to just put them on as is - it will rub off very quickly you just need to be careful braking for the first few times
#28
Posted 09 October 2009 - 07:44 AM
I have started cleaning out the car and finding all the rust areas, although the car has been sitting since 1997 is not so bad and needs couple of welding patches and sills to be done. The car has gone for welding now and should be back next week so I start the paint work and transfering things over.
The good news is that the wirning is in a good state so not much work needed there.
Pics to follow.
#29
Posted 09 October 2009 - 08:19 AM
You must be gutted after all the hard work you put into Albert, how did it come about that it was unroadwothy (re-shelled) good luck with the next shellWell after finding out my car was some how not road worthy (re-shelled). I found another ligit car and started transferring everything over to the new car. Luckily the new car cost me around £200 so not too high of price for the hard work done on the other one.
Pics to follow.
Andy
#30
Posted 11 October 2009 - 08:35 PM
Andy
Well I was looking for the right wiring diagram to follow for the wiring and Dan (from this forum) found it odd that the shell looked like a MK4 so after doing some checking I found it was a MK4 with a different Chassis number on the shell. So the plan is to transfer everything that I can from this car and then chop it up or scrap it. Someone I know locally said he might be interested in the shell as donor body parts.
