Cvh Engine
#16
Posted 26 February 2009 - 11:37 AM
The 1600's are underpowered for their size by todays standards, and can't easily be overbored - I remember tuning companies offering oval pistons to make the displacement bigger up to 1900cc - dodgy.
The 1300 was a better engine for it's size, but still no ball of fire.
The vv carbs are pants.
They always smoke unless you change the valve seals every 5000 miles
The RS Turbo at 134bhp is log.
They're big and heavy, as are the gearboxes.
Escort vans reverted to the old Valencia/Kent engine in about '85 because the CVH was so unreliable.
There are much better engines out there IMO.
#17
Posted 26 February 2009 - 12:38 PM
all i want to no is if its possible and how
does anyone no if that plate that fits the ford engine to the mini box fits and where to get hold of one.
#18
Posted 26 February 2009 - 01:32 PM
anything is possible, you just have to have the time, energy and skill to do it,. the problem is, like i said before, the reason why it hasn't been done is because there are BETTER engines out there. And no, i'm not saying the the CVH is crap or anything. just that you can pick up all alloy,16V, fuel injected engines for peanuts.
and sticking a cvh on a mini gearbox is just asking for trouble. if you spec the gearbox correctly you might get a it to hold 120bhp reliably - ie day in day out for a few years. anymore, and you be fixign it more than driving it?
have you thought about putting a steam engine in?
#19
Posted 26 February 2009 - 01:48 PM
#20
Posted 26 February 2009 - 02:54 PM
#21
Posted 26 February 2009 - 03:20 PM
IIRC the 1600 carbed CVH only pushed about 90bhp in the mid 80's, the XR3i engine about 105 if you were lucky. And the bosch K-Jetronic knows how to sup petrol too.
I also think you will have trouble fitting it in the hole as the 5sp gearboxes are pretty big.
However, if a CVH will fit, you could swap it later for the 2.0 twin cam Sierra unit!!!
#22
Posted 26 February 2009 - 09:07 PM
Looking back I'm glad we didn't spend too much time on it (about a week in total). The engine is very heavy compared to others that are out there. That said, stick to a light engine, the Mini handling seems to suffer hugely with a big engine upfront.
Les.
#23
Posted 27 February 2009 - 11:25 PM
#24
Posted 27 February 2009 - 11:31 PM
also zvh are coolio and Jam sport and NMS are ace saw one of there 230bhp rs turbo mk3 escorts in derbyshire was tasty
#25
Posted 28 February 2009 - 10:08 AM
The Sierra DOHC engine is a very good engine. Plenty of torque in the lower end. However, it's not very tuneable due it the lack of parts (although I'm sure if you spent some time on it and TB's you could be seeing 180+). I'm pretty much with everyone else in this thread. The CVH is by no means a bad engine but there are so many Zetecs floating around which are superior to the CVH it seems daft not to use one.However, if a CVH will fit, you could swap it later for the 2.0 twin cam Sierra unit!!!
#26
Posted 09 May 2009 - 02:26 PM
im not gonna try hard to convince you i just think that the design and engineering behind the cvh was way before its time and that in my opinon is a very good basis for tunning and more resently the ZVH turbo engines have made 450bhp and did hold the world fastest fiesta medal
1, The FWD fiesta records haven't been held by cvh engines for a long long time.
2, I belive Stuart Meads engine was based loosly around a zetec but looked different due to an unusual rocker cover. (unless he's swapped to a duratec since i last saw it)
3, The 2.3 Duratec has been proven to make over 700 flywheel hp in this country BUT also has a weak block.
(the american Drag racers use a block with the liquid cooling cavities filled with chemical metal to get round this)
as for most of the above 3 statements One man has been responsible in the involvement of helping Friends/customers to achieve these goals and records.
The Cvh is a poor designed engine, but can be made to produce good power, albeight with a weight penalty compared to other modern engines power to weight wise.
