2 Litre 8v Turbo Sprint/hill Climb Car
#91
Posted 20 June 2009 - 12:13 PM
Whens the next show your going to then? I fancy having a look around this thing! nice to see something different!
Top marks! lol
Al
#92
Posted 07 August 2009 - 07:09 PM
been spending any time i have welding up the rear end , taking ages but close enough now to start fitting rear suspension back on , :
some seam sealent :
then some black stone chip :
also i have picked up a bigger throttle body of a vauxhall v6 engine , this will be used at some point :
I have also bought some VXR injectors , and have allot of wiring parts ready to go in ...
just need to get the thing on 4 wheels so it can be pushed out !!!
#93
Posted 07 August 2009 - 07:10 PM
top job matt! looks great, sounds alot better too! idles fairly low though... sounds like its dropping to about 600 and struggling a bit?
Top marks! lol
Al
i might be at the 16v mini meet this year ...
idle , dont worry at the mo , not mapped or setup at all yet....
Matt
#94
Posted 07 August 2009 - 08:11 PM
keep up the good work
YetI
#95
Posted 11 August 2009 - 09:34 PM
bad photo :
rear calipers mounted , just need plumbing in now :
you can just see where i have mounted my fuel pump :
daylight shot of the dash , still needs mounting up yet , just resting ..
started to make a battery box , and have started to run the fuel lines through the car.
#96
Posted 14 August 2009 - 03:46 PM
rear brakes plumbed in .. still need to do fronts and bias valve yet ... :
and a shot of a big pile of mess , :
nearly finished both fuel lines , got the hand brake moved back , and one cable made
gear lever bolted down , but just need to weld the linkage back together ...
and drive shafts are still sitting in the drivers foot well.
Got Aron coming round for a few hours tomorrow , so that might get a few more jobs out the way....
#97
Posted 25 August 2009 - 11:44 AM
thanks aron for all that...
made the battery clamp . bit OTT , but works ! , battery all connected/wired up as well now :
all fuel pipes are now in and connected up !
gearlinkage 95% done , but can seem to get any gears
Started car up again yesterday and checked new fuel regulator was working ...
Car would not start at first , no fuel in pump .. but found out someone had wired the fuel pump in backwards !!! lol
just need to fit all the front brakes/shafts now and it should nearly be ready for a drive...
#98
Posted 25 August 2009 - 11:46 AM
got one drive shaft in ... was a sod as there was no clip on the dummy drive shaft .. lucky i still had a passenger innner CV , allthough it was still in the gearbox .. and it was a bugger to get out ... but once it did i put the clip on and all was well.
Started mounting the ECU and new fuse box , done a mod to the megasquirt to give a RPM signal out to feed the dash
A-panel seams bent over.
thats about it , wanted so much more done .. but hey ho ...
did push it out the garage and turn it around ..
will get some pics up tonight.
#99
Posted 25 August 2009 - 11:47 AM
Metro 4 pots thrown on , god i hope they work not got time to fit anything else :
This is the drivers side all done , still got passenger side all to do yet....
And the start of the wiring :
Carputer still to be mounted , and all the fuses and relays need wiring up ...but engine runs so thats the main thing.
Got to fit the brakes on the passenger side ,and then try and run the copper brake pipes to master...
#100
was a bit of a pig , but got there .. got late and could not make to much more banging .. so just started making up the copper brake pipe through car to adjustable brake bias :
But all drives shafts and brakes are on . Hub nuts just need doing tight ...
Aim to get brake pipes finished tomorrow night ..but how its been going .. will be the weekend i guess
#101
Posted 25 August 2009 - 01:09 PM
#102
Posted 29 August 2009 - 08:05 AM
but anyway .. did a few pre flight checks and took it for a spin , :
after a few runs , i let aron have a go , i could then not get him out of it :
and just a general video of engine ..
in my mind the car did not smoke to much ???
#103
Posted 29 August 2009 - 10:03 AM
#104
Posted 01 September 2009 - 09:14 PM
Edited by Ryan218, 01 September 2009 - 09:15 PM.
#105
Posted 07 September 2009 - 08:09 AM
just need to fill in the hole .. allthough next time , i will not cut the edge of the bonnet off ! stupid me .. but will be using this bonnet to make a plug later anyway .. and get a CF bonnet made
got two arches on :
fronts :
could do with being a little wider but will do for now ...
and rears :
also started on the dash , fitted the digi dash , and switch panel , also the boost gauge :
the other mount is for the touch screen monitor for the megasquirt
overall shot of front end :
had to mod rear arch , as it would have hit the exhaust system :
and i fitted the boot lid back on , just in case you have not seen a mini boot here it is :
just working on dash loom at the momment , might as well do it properly so it all works from the word go ....
