2 Litre 8v Turbo Sprint/hill Climb Car
147 replies to this topic
#76 16vmini
16vmini
  • 370 posts
  • Local Club: 16v mini club
Posted 15 May 2009 - 03:34 PM
3" exhaust system 99% done , (percentage might drop later )
back of car , under floor :
Only a small silencer .. will see how loud it is later :shock:
up and over the rear beam axle :
and then , splits to go out each side :shock:
not sure what people think of it ? wanted to be a bit different .. (waits till someone shows it done before )
you can get a better look on sunday :thumbsup:
#77 alexcrosse
alexcrosse
  • 3,786 posts
Posted 15 May 2009 - 05:09 PM
i like it!!!!!!!
gutted, mines only going to be 2.5" :(
#78 Sir Cheat
Sir Cheat
  • 1,171 posts
Posted 15 May 2009 - 08:58 PM
Wow. When you going to upload a vid?
#79 coredevelopments
coredevelopments
    Just On Tickover
  • 7 posts
Posted 15 May 2009 - 09:10 PM
just read through your whole post and love your project. keep up the good work.
Rob
#80 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 15 May 2009 - 09:12 PM
i want that zorst
#81 16vmini
16vmini
  • 370 posts
Posted 20 May 2009 - 10:09 AM
ok my last part of the cooling system arrived today , so rad is all plumbed in and full of water (no leaks yet , will see once its got hot )
fitted my turbo oil feed pipe :
not 100% happy with routing , but will do for now to start her up.
plumbed in the clutch resivour :
i used silicon pipe :? who thinks brake fluid will do nasty things to it ?
i have left a small piece of silicon in some fluid , will have a look in the morning :thumbsup:
i bought a res of a bike ,its small .. but only has to feed the clutch ??
I also got the throttle cable in , its all fitted .. just need a nipple :shock: of some kind to clamp the cable to the pedal.
also nearly done on the turbo oil outlet pipe to sump ... maybe tommorow ...
#82 16vmini
16vmini
  • 370 posts
Posted 22 May 2009 - 06:33 PM
tractor video uploaded ! :
got a top breather pipe missing .. runs bad ... but its running ....
and good to know it started again a few hours later .. not bad for making my own megasquirt !! >_<
had problem this morning with the coil pack , had to go down to scrap yard and find a different type ... that was stopping my spark...
#83 alexcrosse
alexcrosse
  • 3,786 posts
Posted 22 May 2009 - 07:25 PM
sounds like when i started my vaux engine for the first time... awful =p
cant wait to hear it under load mate, youve done a top job on it!
#84 JordanRaisbeck
JordanRaisbeck
  • 408 posts
  • Local Club: NEMC
Posted 28 May 2009 - 09:09 PM
Love this project mate, good job keep up the hard graft!
#85 minidream94
minidream94
  • 1,233 posts
Posted 29 May 2009 - 01:10 AM
First post so sorry if its wrong :D >_< :- :(
but your engine sounds like a tractor LOL
#86 alexcrosse
alexcrosse
  • 3,786 posts
Posted 06 June 2009 - 08:59 AM
comeon! update =p
#87 16vmini
16vmini
  • 370 posts
Posted 06 June 2009 - 07:47 PM
been on family holiday , have been re-doing wiring and fuel lines / fuel pump.
upgraded firmware on ecu , and got a new base map to try .. maybe tommorow i can see if its any better...
Matt
#88 daveeeeee
daveeeeee
  • 684 posts
Posted 07 June 2009 - 12:10 AM
Nice build!
#89 16vmini
16vmini
  • 370 posts
Posted 19 June 2009 - 05:36 PM
YES !!!! found the problem , after wasting money on a new sensor , i found out it was a capictor which needed changing on the MS board to a different value !!! ..simple lol
this is it now reving up ... sounding a bit less like a tractor !!
and this is from the exhaust end :lol:
i am a very happy bunny !!!
#90 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 19 June 2009 - 05:47 PM
NASTY PASTIE I LOVEEEEE IT MAKES ME DREAM OF ALL MY FUTURE PLANS AND HOW CLOSE URS IS
