2 Litre 8v Turbo Sprint/hill Climb Car
#61
Posted 05 May 2009 - 08:06 AM
#62
Posted 05 May 2009 - 08:55 AM
#63
Posted 05 May 2009 - 10:47 AM
first time ive seen your thread lookin awesome
#64
Posted 05 May 2009 - 12:40 PM
Edited by Teapot, 05 May 2009 - 12:40 PM.
#65
Posted 05 May 2009 - 12:42 PM
should post lots more this week
#66
Posted 05 May 2009 - 09:17 PM
i will use the hole where the old filler neck was to mount a fan switch.
top hose outlet moved around to the side , just needs welding up now , will use the fitting above it as a feed back to the header tank i think.
#67
Posted 06 May 2009 - 07:43 PM
#68
Posted 08 May 2009 - 06:25 PM
#69
Posted 08 May 2009 - 06:26 PM
moved fitting around to the side :
welded in fitting for the vauxhall fan switch :
also i bought his old TIG plant , and did my first ever TIG weld , welded in the O2 bung into the down pipe :
not bad for my first attempt , need to feed in a bit quicker in parts ... but should not come off.
#70
this is what it did to the end of the pipe :
ok could be better and cleaner .. but will do the job ... and is all hidden under silicon !
overall shot ...
#71
Posted 08 May 2009 - 06:27 PM
there are a few bits i am not quite happy with , but will see how they go , and improve over time , want to replace all silicon with orange one day anyway LOL
front end on , just goes over it
also re-fitted down pipe , and made bracket to mount to rear of block, as its quite heavy
Just waiting on radiator pipes to turn up
#72
we shall see if it leaks later ... used my TIG on it.
Just waiting on fitting to go into the block then it can be connected up :
Clutch master arrived , so modded it with a mini end , and made up a braided hose for it :
Fitted,anyone know what size thread the resivour port would be ? its a little bigger than the outlet ...??:
and it connected to slave :
a little messy with fittings , but did not quite have the correct one, will change it one day ...lol
shocks fitted :
And made one bracket for the header tank :
not all my bits have arrived ... see what turns up tommorow...
#73
Posted 12 May 2009 - 07:50 AM
but will do for now ...
my ebay bucket seat mounts would not really fit in the mini , so had to make my own mounts , not pretty but should work , seat could only really go in one position due to its width , and the rear suspension setup.
you can see that i cut into the box section , will fill that in with some sheet.
next is to mount the corsa steering column so i can really pretend to drive !
fitted engine earth strap , fitted some vacum hose up to dump valve and waste gate ( not to the same place )
will try and throw the dash in for the weekend , must do some more welding on rear end as well.
not sure if it will be running for L2B , as i still need an adaptor for the oil feed.
and still have rear exhaust section to make (which i have done some on , but no pics yet )
#74
Posted 15 May 2009 - 03:33 PM
#75
Column in place :
that took longer than i thought .. and still needs more work , but will do for L2B ....
now i got to get on an finish that exhaust .... :shock:
