Changing Pedal Box - Wilwood, Tilton Etc
3 replies to this topic
#1 who_loves_the_mini?
who_loves_the_mini?
  • 1,314 posts
Posted 14 February 2009 - 09:06 PM
Im finding that after driving for half hour/an hour or so my foot is starting to ache due to the angle of the pedals. Is it possible to fit an aftermarket pedal box to put the pedals at a more comfortable angle? Is there enough room to fit a floor mounted box or would it have to be a top mounted one?
#2 2lrminivan
2lrminivan
  • 276 posts
Posted 14 February 2009 - 09:51 PM
i have mounted tilton pedals on the floor with a escort servo behind the seat there is a lot of mods to do
can u not bend the pedals or make the seat go back more.
#3 2lrminivan
2lrminivan
  • 276 posts
Posted 14 February 2009 - 09:57 PM
also tilton/wilwood floor pedals are very big and the pedal will end up a long way back because of the length of the master clyinder.also if the MC is below the calipers the fluid can run back to the MC and u will have to a pump the pedal to get it hard again.so it will fail the mot
#4 jayare
jayare
  • 2,093 posts
Posted 14 February 2009 - 09:58 PM
OBP make a top mount pedal box specifically for the Mini - they can be bought from Moss (10% TMF+ discount!) or direct from OBP themselves. Wilwood, Tilton, etc will all need varying degrees of fabrication/modification to fit, whereas the OBP one is a direct fit. If you have a look in the projects section for Matrix (Oz who works at Moss Manchester)'s build diary you can see it fitted.
JR
