I haven't the brown/white wiring going to 'B' on the Voltage Stabilizer.. & the two greens going to 'I' are the wrong type of connector, do I need to change them to spades so they slide in?
Cheers!
i've just finished doing mine and have only just seen this thread...
RE the 2 greens - i had a loom off jupitus and had to change the connectors to spades, i think it's all down to the type of voltage stabiliser you have.
i can't comment on the white/brown at the moment, i'll see if i can see in to the pod from the back later...
attaching the pod to the bulk head was done with a few stainless self tappers and i too removed the plate that was glued to the bulkhead (removing this has made the wheeze of the K&N filter more apparent in the car but i think it's cool)
I have a 1990 mini so the heater pipes got in the way too, i just trimmed the pod with a pair of side cutters a bit at a time until i had the right shape to clear them (make sure you have cleared the hose, you know how much vibration you get in a mini and you dont want to wear through)
I bought a dash tray and dash liner kit from retro retrims (bert998 on here) it takes abit of getting in but looks pretty good when its done. you will have to do a bit of fettling (if you do buy one) to get it around the afore mentioned hoses (if you look carfully in the pictures you'll see it not quite lying right (i still need to fettle!)
sorry about the amount of pictures of the finished product, i've only just done done it and wanted to show you it'll be worth it in the end, a centre binacle is defitiely the way forward!
oh, finally, if you do get stuck take Jupitus's offer upand ask him for help, he was really helpful (cheers Jupitus)
Marv
