Fitting Hif44 Carb
31 replies to this topic
#16 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 16 February 2009 - 03:07 PM
Actually, now I remember, I couldn't get the piston out of the bell housing, which I need to be able to do to change the spring. Am I missing something there?
When I search on Burlen Fuel Systems for 'BCD' I get two needles and when I search for Yellow springs, I also get two options, anyone know which I want?
http://www.sucarb.co...?SearchTerm=BCD
http://www.sucarb.co...archTerm=yellow
#17 GraemeC
GraemeC
  • 7,438 posts
Posted 16 February 2009 - 03:18 PM
The heatshield has a bolt sticking out of the top - whats that for? I can't see exactly how the choke cable attaches, is it anything to do with that?
The bolt is what holds the air filter on when using the big plastic filter box. I'm after one of those and would've gladly swapped you for one with no bolt (as per the picture on the thread)!!
#18 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 16 February 2009 - 03:24 PM
You should have said sooner, it's all fitted now and I can't get the filter off to get the carb off very easily with it being a Minus, so I can't even swap them over for you!
#19 GraemeC
GraemeC
  • 7,438 posts
Posted 16 February 2009 - 03:57 PM
Only just read through the thread (and only realised this morning that the heat shield I have is no good for the filter box)!
I'll keep looking, wouldn't have expected you to strip it all down for me.
Edited by GraemeC, 16 February 2009 - 03:58 PM.
#20 scrippo
scrippo
  • 535 posts
Posted 17 November 2009 - 10:35 PM
Hi all,
I know I'm resurrecting this thread but I hope it can answer some questions I have about the breather system.
Looking at the pics posted by asphalt, they are really helpful but I have the following (probably stupid) questions.
1 - vacuum advance - does this connect via a small pipe to the vacuum advance on the dizzy?
2 - accelerator - happy with this
3 - choke - also ok with this
4 - fuel in - happy with this
5 - overflow/float vent - what does this connect to?
6 - crankcase ventilation - Do I connect pipes to both the flywheel case and crankcase breaters, join them up via a Y piece and connect them here?
7 - adjustment screw - happy with this.
Sorry if these are stupid questions but sometimes I just need to go right back to basics to make sure I'm refitting everything correctly.
Cheers,
Scrippo
#21 scrippo
scrippo
  • 535 posts
Posted 18 November 2009 - 10:22 AM
Bump
#22 Asphalt
Asphalt
  • 2,173 posts
Posted 18 November 2009 - 11:32 AM
Yes.
Originaly there was a smal alu pipe runing 'round the clutch bell to lead overflowing fuel away from the hot exhaust manifold. If it's not present, just try to make something similar, resp. make the overflow point away from the exhaust.
Yes. Join & connect.
The only stupid question is a question not asked :thumbsup: :D
Cheers,
Jan
#23 scrippo
scrippo
  • 535 posts
Posted 18 November 2009 - 06:24 PM
Thanks Jan,
So I can just connect a pipe to the overflow and direct it away from the manifold? I seem to remember a metal pipe on the clutch housing on my 998 which a pipe was connceted to. Is this what you mean?
Scrippo
#24 Burnard
Burnard
  • 3,350 posts
Posted 18 November 2009 - 06:34 PM
Thanks Jan,
Scrippo
Yes that will be what he means, it just make sure the over flow of fuel runs out underneath the engine.
You don't need to direct it away from the manifold, but defiantly keep it away from the electrics.
Fuel will not ignite even if it it dripped onto a red hot manifold.
#25 scrippo
scrippo
  • 535 posts
Posted 18 November 2009 - 06:49 PM
Cool, I'll have a look and see where I can direct it. I'd completely overlooked the breathing system, but now I have an idea of it sorted in my head and can crack on. Thanks guys.
#26 pbrain
pbrain
  • 431 posts
  • Local Club: not yet
Posted 26 May 2010 - 03:56 PM
Those pictures at the start of the thread have just come in handy, this is a very useful thread...cheers & many thanks :wub:
#27 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 26 May 2010 - 04:16 PM
berny i would like to see you test out your theory:
The spontaneous ignition temperature of a fuel is much higher than the flash point. For petrol it is somewhere between 200 °C and 300 °C. Petrol dripping onto the engine casing may not catch fire; petrol dripping on the hot exhaust very likely will.
#28 samg2007
samg2007
  • 499 posts
Posted 26 November 2014 - 09:30 AM
Anyone have the pics from this thread? Sadly they are dead.
#29 Rapidmini59
Rapidmini59
  • 195 posts
  • Local Club: Minifreaks
Posted 09 April 2017 - 07:02 AM
So to continue this thread
I have an electronic aldon fast road yellow distributor and have no vacuum advance.
Where does the vacuum advance from my hif44 connect to.
I was under the impression the i just blank it off as i will not need it.
#30 nicklouse
  • 18,576 posts
Posted 09 April 2017 - 11:42 AM
Correct
