45amp Or 70 Amp Alternator?
20 replies to this topic
#16 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 09 February 2009 - 09:18 PM
This I do not know
#17 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 09 February 2009 - 09:33 PM
This I do not know
oh ok lol
anyone else know how i can find out what amp my alternator is???
YetI
#18 icklemini
icklemini
  • 2,982 posts
Posted 09 February 2009 - 10:01 PM
SPi alt are 45 amp - some books state 55amp but this must be export models. have never seen a 55 or higher on a SPi from standard, all the replacements are rated at 45amp too
MPis are 65 amp.
can tell the ampage on the A127 alternators by checking the colour of the plastic insulating washer bit in the rotor (behind the fan) - usually though these are covered is crap.
-45A (White insulator end washer colour)
-55A (Black insulator end washer colour)
-65A (Green insulator end washer colour)
-70A (Blue insulator end washer colour)
can also take the back off and check the rectifier packs.
Edited by icklemini, 09 February 2009 - 10:03 PM.
#19 yeti21586
yeti21586
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 09 February 2009 - 10:03 PM
MPis are 65 amp.
can tell the ampage by seeing the colour of the plasting insulating washer/plastic bit in the rotor (behind the fan) - usually though these are covered is crap.
cool i shall look tomoz thankies
if i cant see from that anyother way???
YetI
#20 icklemini
icklemini
  • 2,982 posts
Posted 09 February 2009 - 10:05 PM
you will see it - use some brake cleaner to clear the crap out the way and you will see the colour clearly...
#21 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 09 February 2009 - 10:57 PM
how do you no what alternator you have??? as in how many amps it is?
YetI
There's a sticker/stamp on the underside of the alternator stating what type/amps it has.
