Flip Front And Wheel Arches
9 replies to this topic
#1 rudeboy
rudeboy
  • 101 posts
Posted 04 February 2009 - 10:08 PM
hey folks, i'v got a mini pick up with a flip front that i have just bought, now it's running on 12" supelites but doesnt have any arches fitted, i'm planning on keeping it running on 12" wheels although may fit a set of 12x6 revo's, just wondering how to go about fitting front arches on a flip front, i'm guesing they'll need to be cut at the same place as the front flip's up(if that makes sense) any help from folks that have done this and pictures to show the end result would be much appreciated..
thanks
Rudi..
#2 syholl
syholl
  • 710 posts
Posted 05 February 2009 - 10:44 AM
Wood and Pickett ones work quite well. They retain their strength even when you cut right through them. Some arches become quite floppy...
I fitted them, and then cut through with a thin angle grinder blade....
Sy
#3 analogue_radio
analogue_radio
  • 4,897 posts
Posted 05 February 2009 - 11:36 AM
Sy, how have you fixed your front flip down?
#4 syholl
syholl
  • 710 posts
Posted 05 February 2009 - 11:57 AM
It operates with a hydraulic pump, which opens 2 rams. Once closed down, the rams pull the front end in nice and tight, and then a seperate electric solenoid activates, which keeps the front end shut in case of hydraulic failure....
Check out the video below...
Flip front video
Sy
#5 MGMT
MGMT
  • 1,109 posts
Posted 05 February 2009 - 12:14 PM
that is well smart!!! first one ive seen which does it itself!!
#6 rudeboy
rudeboy
  • 101 posts
Posted 05 February 2009 - 04:41 PM
got a link to the wood and picket ones, also some more info on your flip front would be appreciated, wouldnt mind getiing mine like that...
cheers
Rudi..
#7 L.Hurst
L.Hurst
  • 192 posts
  • Local Club: BMC
Posted 05 February 2009 - 04:45 PM
Havent seen a hydraulic pump flip front before! Syholl thats awesome, impressive.
I want one now!
#8 captainjack15
captainjack15
  • 3,925 posts
Posted 05 February 2009 - 06:21 PM
Holy s**t that is awesome!
#9 syholl
syholl
  • 710 posts
Posted 05 February 2009 - 06:44 PM
It was on the front cover of Mini Magazine, so you may have seen it and not realised. Also, our woody estate has the same hydraulic flip front, and that was in Miniworld...
#10 captainjack15
captainjack15
  • 3,925 posts
Posted 05 February 2009 - 10:10 PM
Would there be more details on it anywhere, for example full detailed instructions to how you did it :thumbsup: PWEASE :genius:
This is by far the most amazing thing done to a Mini!!
