Hif44 Vs Hs4
17 replies to this topic
#1 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 02 February 2009 - 06:41 PM
Evening,
I was under the impression that I wanted a HIF44, so I bought one, but a HS4 has turned up. Do I want to keep it, or should I be looking for an HIF44?
What are the technical differences, does Vizard compare carbs? Also, I have an MG Metro inlet manifold, with the four bolts holes to attach the carb, but the HS4 only has two holes - is this going to be a problem, are the carb and manifold compatible?
More info the better!
Paul.
#2 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 02 February 2009 - 06:56 PM
A HS4 is a smaller carb than a HIF44 too.
The 44 is a 1 3/4" carb, with an itegral float (44mm, Integral Float)
The HS4 has a side mounted float chamber and is a 1 1/2" carb.
What spec. car's it for?
#3 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 02 February 2009 - 06:58 PM
And, if someone's sold you a HS4 instead of a HIF44, tell em and send it back!
The HIF38 is more of a comparable carb to teh HS4, as it's a 1 1/2" carb.
Integral float is the way ahead!
#4 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 02 February 2009 - 07:02 PM
MG Metro 1275, standard apart from a performance exhaust. Just measured the manifold at 1.75" and the carb at 1.5". Thats no good is it! I thought the HIF44 was a modern version of the HS4, but they were the same size, you learn something new everyday!
#5 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 02 February 2009 - 07:04 PM
What's the benefit of the integral float? Just interested.
Also, while I'm here, do I need a heat-shield as well as the damping spacer thing?
#6 matt615
matt615
  • 923 posts
Posted 02 February 2009 - 07:16 PM
If you've paid for a HIF44 and got a HS4, then send it back and get your money back!
As said above, a HIF44 is a bigger carb than a HS4. You might be able to get the HS4 to work on your engine, but you really want a HIF44 as you'll get more power.
#7 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 02 February 2009 - 07:18 PM
The HS6 is the old school 1 3/4" carb.
I am no expert on SUs, but I believe the integral float is better in terms of fuel starvation on cornering.
#8 mini_kel
mini_kel
  • 2,851 posts
  • Local Club: EMC/No pub mini club
Posted 02 February 2009 - 07:28 PM
HIF38 is the new version of the HS4 you really need a HIF44
#9 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 02 February 2009 - 07:41 PM
Yes, it looks that way doesn't it! Bah, was hoping to get the car to work this week! I suppose at least I won't have to go outside in the cold though!
#10 lrostoke
lrostoke
  • 6,923 posts
Posted 02 February 2009 - 07:46 PM
And yes you will need the heat shield, on the HIF carbs the heat shield also as the brackets for the choke and the throttle cable.
http://www.minispare...ty=pb&pid=38526
#11 Pooky
Pooky
  • 5,691 posts
Posted 02 February 2009 - 07:50 PM
I've got a HIF44 for sale, it's guaranteed* :thumbsup:
*to be a HIF44
#12 Pooky
Pooky
  • 5,691 posts
*to be a HIF44
#13 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 02 February 2009 - 08:46 PM
to be a HIF44
That's the sort of guarantee I'm looking for..........
#14 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 02 February 2009 - 08:59 PM
First things first return the HS4 you got sold and demand a refund!!!!!!!!!!!
#15 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 02 February 2009 - 09:14 PM
Yeah, thats all in hand, was an honest mistake etc, not really a problem, just annoying as I wanted to get the car working asap!
