Welding Sills (mot Advice)
28 replies to this topic
#1 mk=john
mk=john
  • 1,167 posts
  • Local Club: Milton Keynes Mini Club, Mini Cooper Register
Posted 01 February 2009 - 06:14 PM
Hi
i am currently restoring my 1960 mini minor. The new floor panels and outer sills on these are one part, and i am currently just doing the Right hand side.
Anyway, on the original car, it looks like the sill and door step were roller welded together, the spotwelds being 5 or 6 mm aprt from eachother.
I have plug welded the new panels together (with my MIG welder) at approximately 20mm apart between the welds. However, my plug welds are bigger in diameter then the original spotwelds.
Is this OK for an MOT, or do i need to carry out more welding?
John
#2 spikyrob
spikyrob
  • 264 posts
  • Local Club: NW minis
Posted 01 February 2009 - 06:27 PM
when i replaced my sills and spot welded them the MOT man insisted they had to be seem welded, as at the factory they were roller welded but in a continuous spot weld (2 copper wheels rotating permanently charged) same as the fuel tanks.
Rob
#3 Ethel
  • 25,966 posts
Posted 01 February 2009 - 06:32 PM
I don't think I've seen any production cars, including Minis, spot welded that closely together other than where it's to create a waterproof joint. If the panels bow between the welds you might consider adding more, otherwise I wouldn't bother.
On sills Rob, are you sure?
It's a misconception that continuous welds are stronger. The heat and surface tension of a weld thins and weakens the metal next to it and a continuous weld creates a stress riser like creasing a bit of card. Correctly spaced spots will load in tension like a nut 'n bolt.
Circumference is pi x diameter, so a row of spots with gaps that are twice as wide as the welds have just as much metal joined as a continuous weld.
#4 dlm
dlm
  • 175 posts
Posted 01 February 2009 - 08:01 PM
Rob
He is wrong. The sills were spot welded at the factory and not roller welded. The only roller welding done on the body I believe was the roof.
#5 In-a-mini
In-a-mini
  • 831 posts
  • Local Club: smag (southend mini action group)
Posted 01 February 2009 - 08:59 PM
I can not say for the early minis but all i have worked on have has spaced spot welds. And as previously stated the continuous spot welds were only to seal IE tanks and roof panel withing gutter.
In my experiences it is only badly educated/taught Mot testers that have said such things and when they have gone back to the testers guide and re read it the problem was resolved.
Edited for spelling as pointed out glad i made you laugh
Edited by In-a-mini, 02 February 2009 - 05:20 PM.
#6 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 01 February 2009 - 09:04 PM
sounds perfect to me if u dont have a spot welder, and not a mot fail, just make sure its all nice and tidy
dave
#7 cambiker71
cambiker71
  • 1,050 posts
  • Local Club: Cambscustomclassics.com
Posted 01 February 2009 - 09:11 PM
Hi
John
Sounds ok to me, so long as the panels are replaced as they were originally and not repair section panels then plug welding where spot welds were originally is fine. Any other weld repairs need to be seam welded for a MOT pass.
#8 edi57
edi57
  • 821 posts
Posted 01 February 2009 - 09:38 PM
The way you have welded your sills is acceptable for the MOT.
#9 mk=john
mk=john
  • 1,167 posts
Posted 01 February 2009 - 10:30 PM
Hi Guys
Thanks for the help. I am also taking lots of photos of ythe restoration work, to include all welding, just in case the MOT inspector asks to see how I have welded something. So, I will leave the welding for the sills then? I have spotwelded at a distance of 20mm as mentioned.
I guess once it is all sealed and painted, the MOT guy can't see the welding anyway??? I thought I would mention that, and hence why I am taking lots of photos of the whole restoration process.
#10 rosewhite
rosewhite
  • 486 posts
  • Local Club: LSMOC
Posted 01 February 2009 - 10:34 PM
In my experiences it is only badly educated/taught Mot testes that have said such things and when they have gone back to the testers guide and re read it the problem was resolved.
:) :( :dontgetit:
sorry to spam, but that really made me laugh!!
#11 tomsbluemini
tomsbluemini
    My Blue little monster
  • Area Managers
  • 1,498 posts
  • Local Club: LSMOC / Kentish
Posted 01 February 2009 - 10:35 PM
Mot testes
Sorry to comment on your typo mate, but this made me laugh SO much!!!!!
#12 mk=john
mk=john
  • 1,167 posts
Posted 01 February 2009 - 10:39 PM
Mot testes
What made you laugh?? The fact that I'm not stupid by bodging welding, spending hundreds for paintint etc and then finding out it fails the MOT??
#13 tomsbluemini
tomsbluemini
  • Area Managers
  • 1,498 posts
Posted 01 February 2009 - 10:41 PM
Mot testes
no - you wrote TESTES...
***giggles like a girl***
Edited by tomsbluemini, 01 February 2009 - 10:42 PM.
#14 daemonchild
daemonchild
  • 2,341 posts
  • Local Club: Unknown
Posted 01 February 2009 - 10:47 PM
Mot testes
Like you hear at gigs, as in Testes, testes, 1,2 ... THREE?!
#15 Ethel
  • 25,966 posts
Posted 02 February 2009 - 12:32 AM
Mot testes
It's ok no one's saying you're talking b0ll0x :)
