Not Big Enough Socket
Posted 28 January 2009 - 06:37 PM
pain in the arse iv got take my disk brakes off and havnt got big enough socket for the castle nut yeh i could go and buy one but could i use a spanner couldnt i...just take longer to take off cause of studs getting in way?
Posted 28 January 2009 - 06:40 PM
The size is either 1 5/16" (inch & five sixteenths) or if quite a new car (MPi) or replacement nuts have been used previously they could be 34mm.
Posted 28 January 2009 - 06:43 PM
Posted 28 January 2009 - 06:44 PM
hi there
Good luck!!!
That nut should be torqued up to about 150 ft/lbs.
I wouldn't rely on a spanner to undo it. I would get and impact socket (the black ones) and a good quality breaker bar.
I needed a 1 5/16 socket for my steering wheel nut. One shop said he hasn't sold imperial sockets for ages and then only went up to 27mm!
In the end, I used two large adjustable spanners and then measured the nut with a vernier guage. It came out to just under 34mm. So I got one from Halfords. Bit steep at around £10 but it is a lot easier than spanners as I can use my torque wrench to get the right torque instead of guessing it.
Edited by Brigbeale, 28 January 2009 - 06:49 PM.
Posted 28 January 2009 - 06:46 PM
hi there
Good luck!!!![]()
cough cough...lol
Posted 28 January 2009 - 06:51 PM
Posted 28 January 2009 - 06:54 PM
i dont what the imperial equivalent for the castle nut is,, but i bought an impact wrench socket 33mm from halfords. that fits snuggly. to be fair it would be a pain in the arse to undo the nut with a spanner, iv had a breaker bar on them before now with someone in the car with the car in gear and their foot on the brakes and it was still a struggle,, to reitterate,, pretty darn tight indeed!!
well im a loner tomoro so ill just wack steel bar in between the studs the use the socket or whatevr in morning...maybe my teeth...something...lol
