Oil Pressure Warning Light / Oil Pressure Switch
RacingGreen
, Aug 09 2005 10:32 AM
11 replies to this topic
Posted 09 August 2005 - 10:32 AM
After looking at oil pressure gauges for my car last night, i noticed that the oil pressure light would not come on when i would turn the ignition on. The no charge light would come on but the oil one will not.
Is this anything that needs to be rectified? I had a look at the pressure switch on the engine, there was a brown and white wire going onto the switch but the switch looked like it was no done up the full was as i could see alot of thread left.
Any suggestions on what i can do to solve the problem?
Mike
Mike
Posted 09 August 2005 - 11:42 AM
Right, the switch has whats called a taper thread on it, basically, it's tapered so that it tightens up to for a oil tight seal ( remeber it has to withstand over 50psi! ), so would not worry about that, but what has happen to me recently is I've had a couple go a bit wobbly on me so may be worth trying an alternate sender..
The wire is the right one, and maybe worth running a continuity check on it ( ie it's actually intact ! ) this is connected to one side of the light and out of the other should be a green wire connected to the voltage regulator, which are also notoriously unreliable... as a side line do your TEMP and FUEL guage work correctly as if the voltage regulator is playing up, these will also have a tendancy to missread.
Posted 09 August 2005 - 11:45 AM
Could be an idea to clean the contacts too to see if its just that, i did that with mine and it worked fine.
Posted 09 August 2005 - 11:52 AM
yes, the temp and fuel gauge work fine, its just the oil light that doesn't, i checked everything else when i noticed it.
Posted 09 August 2005 - 12:15 PM
Don't trust it! go and buy an oil pressure gauge with a capillary tube and T-piece. much, much more reliable.
Posted 09 August 2005 - 12:17 PM
Take the wire off the sending unit. Connect the bare connector the the chassis or engine block to ground it (make sure you have a good, clean connection). Switch on the ignition and look at the dash, the oil light should be on... which would indicate you have a faulty sender. If the light is NOT on, check the light bulb itself. If a new light bulb doesn't fix the problem, you have a problem with the wire.
Posted 09 August 2005 - 12:18 PM
thats actually what i was looking at buying when i noticed that the light didnt work.
Are the tim gauges any good?
Posted 09 August 2005 - 12:27 PM
Tim are the budget end of the market, but do work...
Posted 09 August 2005 - 12:29 PM
The mechanical oil pressure gauges typically aren't referred to as "capillary tube" gauges... even though they do connect to the block with tubing. This term is more commonly reserved for the temperature gauges that work by measuring the pressure/expansion of a gas in the expansion bulb (methylene chloride?). Just call it a mechanical pressure gauge when you go to the parts store and they'll know what you want.
Most mechanical pressure gauges are good. Some are more accurate than others. I'm a big advocate of VDO instruments but I'm sure you'll find other, equally good instruments at your local parts store.
I'd still fix the warning light even if you decide to add a gauge.
Posted 09 August 2005 - 02:50 PM
I had a look behind the clocks and i found a wire brown and white wire going into the large plug that plugs into the ciruit board. So the wire is there. Have also been looking at some of the gauges, the vdo one look good.
Is the any way for me to check to see if it is the bulb thats faulty?
Thanks for all the help
Mike
Mike
Posted 09 August 2005 - 04:12 PM
Re-read my first post on how to check the bulb/wire.
Posted 09 August 2005 - 06:14 PM
sorry about that, have now earth the wire and the light came on, so i will go and get a new sensor tomorrow.
Thanks for all the help guys. Much appreciated.
