What Random Facts Do You Know About Other Makes Cars?
154 replies to this topic
#61 jammiedodger26
jammiedodger26
  • 620 posts
Posted 27 January 2009 - 11:07 AM
Apparently the Lambo Miura was designed to look like a profile of an aircraft wing!
This made it look great and very aerodynamic....however when you get over 70mph it starts to take off!!
#62 techno-steve
techno-steve
  • 818 posts
Posted 27 January 2009 - 12:09 PM
hitler promised everyone who joined his army a brand new vw beatle. and then actually he dint give out even 1 :thumbsup:
#63 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 27 January 2009 - 12:38 PM
Lamborghini first started out by designing and building Tractors.
He then Challenged the top sports car makers, Porche etc etc that he could make, as good if not better, sports cars...
And heyho, we now know Lamborghini more for his cars, than we do his tractors.
Actually Ferruccio Lamborghini started producing his own cars after he took his Ferrari 250 back to the factory to complain about the clutch and they laughed him out of the door. Enzo Ferrari said something like 'the fault lies with the driver, go back to your tractors you silly little man' and he got a bit angry. So he took the car back to his own factory and stripped the gearbox, realised he could make a better one and put together a group to design his first car the next week. This was called the GTV and was released the next year as the 350GT. These were GT cars and his initial aim was to build GTs better than Ferrari did, they didn't start making sports cars until the Miura. They still make tractors too by the way, and marine diesel engines.
Ford CVH stands for central valve hemisphere as the valves are at 45 degree angles and its a semi circlular shape the cylinder head design ment it met exhaust emmisions without a cat but was made to fit one due to law !!
CVH stands for Compund Valve-angle Hemispherical. Ford never successfully created a lean burn head as they intended. The more they worked on it the more they realised that the ideal lean burn shape was already patented by Harry Weslake (who can imagine where that type of combustion chamber might actually be used? :thumbsup: ). If the car produced the required levels of emissions without a cat it would not need one. There is no law in Britain requiring a car to run a catalyst, there is only an emissions requirement.
Speaking of the Miura, it's got a transverse V12...an idea they niked from the mini..
Not really, Mini was not the first car with a transverse mounted engine.
This is a commonly believed myth.
the audi quattro was the first 4wheel drive CAR
I know this has already been corrected but I believe the first 4 wheel drive road car (as in not a vehicle designed for off road use or the military) was the Jensen FF of 196...5 ish?. Also the Audi Quattro was only the first 4 wheel drive rally car in the FIA world rally series because it just happened to be introduced in the year the FIA changed the rules to allow 4 wheel drive, which was previously banned. There was a time before the insideous controlling presence of the FIA in rallying though and BMC were developing the Twini Cooper specifically to use as a 4 wheel drive rally car when they started to loose dominance in the sport in the late '60s. Unfortunately the car was not homoligated (they didn't have the guts to sell it to the public) and so couldn't be entered in the rally but it was developed as a rally car.
#64 Ethel
  • 25,725 posts
Posted 27 January 2009 - 01:10 PM
Austin A40 first production hatchback
Dolomite 16valver... Princess wipers... Metro asymmetric rear seat...Maestro electronics... Clubby printed circuits.... K Series... Austin 7 & Mini just about everything else - how did the Brit motor industry lose its way so badly?
#65 Burnard
Burnard
  • 3,350 posts
Posted 27 January 2009 - 01:32 PM
if this is rong im going to look stupid.
the mini designer was the first mini to have a vainty mirror on the drivers side as standerd.
#66 Git
Git
  • 1,269 posts
  • Local Club: Humanity
Posted 27 January 2009 - 02:21 PM
Quote from Wikipeidia again..
Taking a cue from the Mini, Lamborghini formed the engine and gearbox in one casting and they shared common lubrication until the last 96 SVs, which used a limited slip differential requiring appropriate oil.
#67 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 27 January 2009 - 04:07 PM
It's the common crank and transmission case, common lubrication setup they are referring to when they say that, not the arrangement. I think the first transversely mounted engine was in a Renault. Renault invented lots of things.
Although I must admit I didn't know there were any other engines in the world that shared oil and space with their gearbox!
#68 RsSpyder
RsSpyder
  • 374 posts
Posted 27 January 2009 - 05:43 PM
The Porsche Carrera GT's wheels are made of Magnesium, and the car was originally designed to compete at Le Mans, but due to regulation changes it ended up becoming a production road car.
#69 MuppetDonkey
MuppetDonkey
  • 53 posts
Posted 27 January 2009 - 05:58 PM
Enzo and Dino are two cars Named after people but Mercedes itself is named after the original designers daughter.
The least inspiring car 'name' must be TVR - short for Trevor
#70 Git
Git
  • 1,269 posts
Posted 27 January 2009 - 06:14 PM
Dino was Enzos son
#71 minimib
minimib
  • 150 posts
Posted 27 January 2009 - 06:33 PM
was it not ment to look lyk a bull with the doors opens like the horns ???? pretty sure that true lol
and MG stands for Morris Group it was more there sport car range
and cant mind what car it is some sort of aston martin lagonda uses the same rear lights as a morris marina lol i think :P
#72 scrog
scrog
  • 640 posts
Posted 27 January 2009 - 06:53 PM
the 1100 mini special is the only mini fitted with a cigarette lighter
#73 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 27 January 2009 - 06:55 PM
mine has :P
#74 captainjack15
captainjack15
  • 3,925 posts
Posted 27 January 2009 - 07:00 PM
As standard.
#75 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 27 January 2009 - 07:13 PM
Not unusual for race or rally wheels to be made of magnesium alloy, proper Minilites are magnesium.
It is indeed.
It doesn't. It supposedly stands for Morris Garages and was originally a seperate company based out of a small independant Morris garage in Abingdon who built new bodies for Morris chassis and tuned the cars for better performance.
