Loose Wheel Nut
Posted 22 January 2009 - 09:43 PM
my mums mini is suffering from an reoccuring problem of wheel nuts coming loose. In december her rear wheel actually came of her mini and bounced over a hedge, luckily she was fine and no one got injured,at the start of the january she had to stop on a motorway after hearing "knocking noises" and discovered more loose wheel nuts, and today my dad had to yet again tighten some wheel nuts.
We dont know if someone is trying to steal her 13" alleycats wheels ( they have locking nuts on them) or wheather its a combination of the vibrations from her 1310 engine and very stiff suspension. just wanted to get other peoples views / experiences / advice as someone could get seriously hurt. thanks in advance for any replies
Posted 22 January 2009 - 09:48 PM
Posted 22 January 2009 - 09:50 PM
torqued up right??
Posted 22 January 2009 - 09:57 PM
dave
Posted 22 January 2009 - 09:59 PM
put some locktite on them that should hold them on
Posted 22 January 2009 - 10:13 PM
Do not do this, it's not the correct way, it's fixing the symptom not the cause!
I'd suspect wrong nuts for the wheels, or they're not being tightened properly.
Did the nuts come with the wheels?
How are you tightening them?
Is there any damage on the threads?
Are the studs properly seated within their flanges?
Is it always the same wheel, or different ones?
Dave
Posted 22 January 2009 - 10:18 PM
a few racers have been caught out like that
Posted 22 January 2009 - 10:41 PM
Posted 22 January 2009 - 10:44 PM
I always use the "URGH! Ah, that will do" system for wheel nuts. Right up until my wheel tried to come off at 70mph. Bad noises and a pull over later I found that 3 wheel nuts could be undone by finger and the wheel was trying to make a run for it.
Good thing I was 15miles from home with no tools.
On another note, payphones don't take money anymore.
Posted 23 January 2009 - 01:11 AM
That was my first thought.
Classic Big Adam there!
Edited by Dan, 23 January 2009 - 01:13 AM.
Posted 23 January 2009 - 08:15 AM
That's why I asked this one, if it's always a different wheel then I'd be looking at jacking the whole car up, all four wheels off, check studs in flanges, and go round individually reseating studs fitting wheels and torquing wheel nuts!
D
